Home › Forums › Products › Stompboxes › How is it that my 250K ernie ball works?
April 9, 2015 at 10:26 pm #112484
I already own a 250K volume pedal so I ignored the advice to use a 25K pedal. The 250K works with no issues whatsoever. Why is that? Oh yeah –I am using it with a h9 MAX
I play a fender strat with passive N3
also Gibson trad pro II also with passive pick ups –is it the passive pick ups that make this possible
Thanks
April 9, 2015 at 10:58 pm #127704
Did you go through the calibration (enable calibration/disable calibration) procedure on the H9 or in H9 Control?
April 10, 2015 at 2:36 am #138795
I was kind of unclear–but I have a h9 MAX and the direction specifically say that the type of expression pedal I have should not work–but it works perfect without and flaws
just wanted to spread the word
April 10, 2015 at 4:58 am #138796
So, did you go through the calibration procedure, or did it just plug in and work?
April 10, 2015 at 10:43 am #138800
I went through the calibration procedure
April 10, 2015 at 2:51 pm #138802
250k will work after a fashion if you go through the calibration procedure, but you'll probably get a weird control relationship – either the top or bottom of the pedal range will be very compressed.
For this reason we recommend the lower resistance pedal – I don't think we actually say other values won't work (I imagine people will correct me if I am wrong).
