Home › Forums › Products › Stompboxes › How to get H9 Bluetooth to stay connected on a Mac?
- This topic has 10 replies, 5 voices, and was last updated 3 months, 2 weeks ago by
bohan
Eventide Staff.
October 19, 2021 at 3:59 pm #159640
I have been using the H9 with H9 Control on my Mac via USB. But the noise is too distracting. The second I unplug the USB cable the noise goes away. So I figured I would try Bluetooth. But I am having no luck keeping H9 Control connected via Bluetooth. The Mac says connected for about 20 seconds and then changes to disconnected. My H9 has the latest firmware and my Macbook Pro 2019 has the latest version of Catalina. I am working with support on this but I have already done all the suggestions and more. Hoping someone else has found a solution. Thanks
October 21, 2021 at 12:41 pm #159683
How far is the H9 from your mac? Would the connection stays more stable if you put it closer?
October 21, 2021 at 12:49 pm #159684
The H9 is right next to the Mac. When I can get the H9 connected to the Mac via Bluetooth it doesn’t stay connected long enough to load H9 Control. I have deleted BT preferences in the Mac. Done the Debug process to reset the Mac’s BT. The H9 just doesn’t stay connected to the Mac.
October 21, 2021 at 12:58 pm #159686
Did you connect your H9 in the H9 Control app?
Please try that instead of connecting in the Bluetooth settings.
Open H9 Control -> Manually Select a Device -> Connect via Bluetooth -> Choose your H9 and click Browse
October 22, 2021 at 9:23 am #159696
I was following the H9 manual that says to connect the H9 via the Mac’s Bluetooth settings. And I had previously tried connecting via H9 Control without success. But I went back and tried connecting via the H9 Control app and this time it worked. In the Mac’s BT settings it shows the H9 but says the H9 is not connected. So I load H9 Control and have to click on Manually Select a Device, Connect via Bluetooth. It takes me to the Mac’s BT settings and I click on the H9 and the options are Cancel or Browse. I click Browse and the H9 connects. The process and Mac’s terminology seems a little strange but at least it seems to be working! Thank you!!
December 26, 2022 at 6:45 am #167960
I have the same bluetooth problems, both on my iPad and iPhone 12. Whatever I try, the option ‘Manually select a device’ does not show up in the control app.
Any help would be great.
December 26, 2022 at 7:28 am #167961
Look guys, I went through these problems with mine too, on the Mac I solved more or less, doing the following, turning off my mouse and Bluetooth keyboard, connecting the H9 and only when it was time to name the Patch I connected. But even so, sometimes he disconnected out of nowhere. The best way to use it for me was through the USB cable. Now with my iPhone 12 Pro Max and IPad 4 it stayed longer connected. Really this Bluetooth connection was very bad, as today I have the H90 and it still does not have this type of connection, via USB-C cable it never crashed. Plus Eventide in a future update will include the wireless connection again.
December 31, 2024 at 6:14 am #187256
Hello I know I am late on that but since I changed my setup I would like to stop using USB and rely on bluetooth !
Any way of doing that in a reliable way now ?
Thanks, Vincent.
December 31, 2024 at 1:47 pm #187309
Does your H9 connect to your Mac via Bluetooth? If not, what error messages do you see?
December 31, 2024 at 4:52 pm #187310
After trying and trying today I noticed one thing : if I do not connect to the H9 via the bluetooth panel of the Mac but only via the H9 App it looks to be more stable …
January 2, 2025 at 10:46 am #187329
Yes, you are supposed to connect to your H9 in H9 Control, not in the Bluetooth Settings on your Mac.
