How to “Kill Dry” in SP 2016??
Home Forums Products Plug-Ins How to “Kill Dry” in SP 2016??
    • #115421
      Armando
        Hello!
        I thought the “KILL” button on the plugin would do this but it doesn’t do a true “Kill Dry”
        How is this accomplished so all the plugin passes is the “Wet” signal. I’ve got it on an Aux channel. Thanks!!
      • #152294
        pmcculloch
          Hi Armando, you should just be able to accomplish this on an Aux Channel by setting the mix to 100% wet.  If you find that the mix still sounds a bit too dry, try increasing the value of the position control, since this will adjust the balance between early reflections and late reverb.  Additionally, you might try increasing the predelay.
          Armando wrote:
          Hello! I thought the “KILL” button on the plugin would do this but it doesn’t do a true “Kill Dry” How is this accomplished so all the plugin passes is the “Wet” signal. I’ve got it on an Aux channel. Thanks!!
