Home › Forums › Products › Stompboxes › How to ‘m_bandtap’ (eclipse) with a H9 stompbox
November 11, 2018 at 12:47 am #115053lord_mariusParticipant
hi folks,
i’m trying to emulate this sound that apparently are 4 delays in series with some filtering. The original device is the Eventide Eclipse but the h9 can do this sound right? or perhaps in combination with another pedal?
best
November 11, 2018 at 1:47 am #150565lord_marius wrote:
I'm trying to emulate this sound that apparently are 4 delays in series with some filtering. The original device is the Eventide Eclipse but the h9 can do this sound right? or perhaps in combination with another pedal?
If you just want to use an H9 to do this effect, Resonator would best suit you.
If you have another delay pedal, you can try Band Delay with it.
November 11, 2018 at 7:54 pm #150568lord_mariusParticipantbohan wrote:lord_marius wrote:
I’m trying to emulate this sound that apparently are 4 delays in series with some filtering. The original device is the Eventide Eclipse but the h9 can do this sound right? or perhaps in combination with another pedal?
Thanks, i’m trying with the resonator but i’m having trouble with the rhythmic pattern of the notes in the video.
November 12, 2018 at 3:52 am #150571lord_marius wrote:
Thanks, i'm trying with the resonator but i'm having trouble with the rhythmic pattern of the notes in the video.
It cannot be identical. Try first several factory presets of Resonator in H9 Control and tweak the Length and Feedback parameters. You should be able to get a similar sound.
September 7, 2019 at 2:13 pm #152689nacholaborde54Participant
Hi
I would like to know how I can get a similar sound using two H9
how can i replicate the master feedback of the Eclipse’s mbandtaps algorithm ??
