How to permanent change to dual routing in pre/post on H90?
Home Forums Products Stompboxes How to permanent change to dual routing in pre/post on H90?
Viewing 7 reply threads
    • #174200
      eventide_user12123
      I use the H90 as a permanent effects device via send/return on my mixer. This works perfectly. Nevertheless, I’m looking for a way to store dual routing in pre/post fix in the routing. I use both stereo effects on a sepperate path. Whenever I change a program, the routing is usually changed. However, it is important to me that this remains set as I permanently use effects paths as stereo in my mixer. Is there a way to fix dual routing in pre/post or to only display the effects that have this FIX setting? Thanks
    • #174202
      joecozzi
      Once the H90 is set to Dual Routing Mode it’s up to you to set the signal routing for each Program in your Playlist. The only way to ensure every Program has Preset A in path 1 and Preset B in path 2 is to do it manually. The easiest way to copy this configuration is using H90 Control and just copy it to every position.
    • #174203
      almostmuzic
      Similar issue I have … Insert Routing, 2 stereo instruments “using H90 as a mixer” .. Cant browse the presets or I loose the routing config.
      I have to manually config each preset???
    • #174206
      joecozzi
      Yes, that’s correct. The pedal doesn’t know whether you want two Presets in the PRE position, two Presets in the POST position, or one on each.
    • #174207
      almostmuzic
      How can we make it know that’s the master routing setting I want keep? 🙂
    • #174208
      joecozzi
      You design your Programs as such.
    • #174210
      almostmuzic
      Thats pretty inconvenient…. (naturally) I want to browse the programs the pedal came with ..  from 2 Inst setup…  And if I change my config .. I need to remake Programs?
      Crazy how routing doesn’t sit on top of a program.
    • #174217
      tsternfeld
      The programs include the routing. For people who want to do programs with different routings (some have A+B in pre, some have A as pre and B as post, etc) it would be just as crazy to have the routing stay the same while the programs change.
      If you are using the H90 as a send in your mixer (and never want to have two algorithms on a single send) it may make more sense to focus on the Presets, as those will give you single algorithms with settings.  Then when you can find combinations of algorithms you want to use together, save them to a User List as a program.  The programs we’ve included by default are designed for the pair of algs to be used together, so may not even make sense for your use case.
