how to send sysex floating point numbers from Cycling 74 Max?
Home › Forums › Products › Rackmount › how to send sysex floating point numbers from Cycling 74 Max?
    • #108825
      I have a Max patch that controls a preset on my H7600. Everything works fine except with floats. I have a delay value in seconds and I can't change the values after the point. I can get 1 second or 2 seconds but I can't change it to values between those like 1.3 for example.
      A solution to this is to use vsig editor to change delay time units to milliseconds instead of seconds to avoid using floating points, but before doing this I would like if someone have another suggestion.
    • #123525
      I got it! I just added a 46 (an ascii point in decimal values) at the sxformat object.
