I have the same doubt. Because nobody has answered the question during these years?, The question seems very logical to me.
The signal path :
Guitar -> FACTOR Input 1 -> FACTOR Output 1 -> Amp -> Send -> FACTOR Input 2 -> FACTOR Output 2 -> Return
According to the manual, Output 1 is connected to the amp input, so In Lvl should be set to GUITAR and Out Lvl should be set to AMP(Pre routing).
But Output 2 goes to the amp return then In Lvl should be set to LINE Out Lvl should be set to LINE(Post routing).
In this case how can I properly set the Lvl toggles?
For now my solution is using two more pedals and set the two Lvl toggles to LINE :
Guitar -> Pedal 1 -> FACTOR Input 1 -> FACTOR Output 1 -> Pedal 2 -> Amp -> Send -> FACTOR Input 2 -> FACTOR Output 2 -> Return
Is this a possible solution?
Thanks.
