How to set up MIDI control for plugins in Logic Pro
Home › Forums › Products › Plug-Ins › How to set up MIDI control for plugins in Logic Pro
    • #115957
      osumosan
        How is this done? MIDI signals in Logic do not seem to affect the plugins at all.
      • #155070
        tlongabaugh
          Hi-
          MIDI control of audio effect plug-ins in Logic is a bit confusing.
          You need to create a new instrument track, and select the plugin as the instrument (it wll be listed under AU MIDI-Controlled Effects->Eventide->Plugin Name). Then, select the track with the audio you want to process in the Sidechain menu in the top right of the plug-in window. Now, if you have the instrument track selected, you should be able to play/record MIDI notes affecting the source audio.
          -Tom
