Home › Forums › Products › Stompboxes › How to turn ON/OFF 2 eventide stompboxes connected by MIDI (timefactor as master and space as a slave)??
January 5, 2018 at 3:40 pm #114530
4_cuerdas
ParticipantHi, I use a timefactor as a master and a space as a slave (connected via MIDI) and I know I can select the presets in the timefactor and the space will change the preset as well, but when I want to turn off the active preset in the timefactor the preset in the space stomp box stays on. I would like to turn off/on both stompboxes only using the timefactor, can this be done? Is there some MIDI settings I have to program to achieve this ?, if so, can somebody point me in the right direction? Cheers
January 14, 2018 at 5:59 pm #148101
Sorry – can't be done as you describe. Assuming that by "off" you mean bypass, the problem is that when you bypass one unit, it does not send a MIDI message saying that this happened.
You probably need some kind of pedalboard to achieve this.
January 14, 2018 at 7:07 pm #148105
4_cuerdas
Participantnickrose wrote:Sorry – can’t be done as you describe. Assuming that by “off” you mean bypass, the problem is that when you bypass one unit, it does not send a MIDI message saying that this happened.
Hi Nick, and thanks for your reply.
Yes I meant bypass. I use a digitech 3 button switch pedal with my Eventide stompboxes. I use it to activate the “infinite delay” in the Timefactor, to switch bank down (on both units) and to tap tempo. Is it possible to use one of the button-switches of my ext switch pedal to bypass both units?
Cheers
If it suits your other needs, you could connect the AUX switch(es) in parallel, either individually or with a TRS Y-lead. Make sure this does not create a ground loop.
January 15, 2018 at 10:31 am #148111
4_cuerdas
Participantnickrose wrote:4_cuerdas wrote:Is it possible to use one of the button-switches of my ext switch pedal to bypass both units?
Ok. Thanks for your reply Nick.
Cheers.
January 18, 2018 at 7:07 am #148144
aliengtr
Participantyou need a midi pedalboard for this I would think. I use a soleman which can send midi cc messages to turn on/off h9’s…
Denis
January 18, 2018 at 4:48 pm #148155
You can also use an aux switch to turn on/off the first stompbox (set the mapping of this switch to Bypass) and use a MIDI cable to connect these two stompboxes. Set a CC number for this aux switch (TIP, RING, or T+R, depends on which switch you want to use) in the first stompbox's XMT CC setting. And assign this CC number to "Toggle" in the second stompbox's RCV.CTL (assign received MIDI CC to pedal functions) setting accordingly. By doing so, you don't have to use a MIDI pedalboard.
January 18, 2018 at 7:14 pm #148157
4_cuerdas
Participantbohan wrote:You can also use an aux switch to turn on/off the first stompbox (set the mapping of this switch to Bypass) and use a MIDI cable to connect these two stompboxes. Set a CC number for this aux switch (TIP, RING, or T+R, depends on which switch you want to use) in the first stompbox's XMT CC setting. And assign this CC number to "Toggle" in the second stompbox's RCV.CTL (assign received MIDI CC to pedal functions) setting accordingly. By doing so, you don't have to use a MIDI pedalboard.
Perfect!. I have already a Digitech f3sx and I can assign one of the switches to do the bypass. Thanks a lot for your answer!
Cheers!
