Home › Forums › Products › Stompboxes › I have 3 H9’s..
Tagged: Eventide, h9, mastermind, possibilities, rjm, three, tips, tricks
August 30, 2015 at 10:51 am #112810
salplant
MemberI’m pretty familiar with them and have been working with them for a while now, just wondering if i’m missing any cool tips/tricks or any cool preset combinations, or just missing any capabilities i could be using?
August 31, 2015 at 2:54 pm #140367
skywriter
ParticipantHi! good question! I like your midi foot controller. I have four H9’s but haven’t put together a framework like yours to coordinate them. One suggestion I might have, that could have been taken care of with your pedal board, is the assignment of aux and performance switches for each of your H9’s. I see you have a pedal, and assume it’s configured as an expression pedal for one (or more) of the H9’s.
For now, mine are ‘setup’ with no preset configuration. I’m also not using them with only a guitar. For me, it’s a piece (or several pieces) of studio gear for any use. Although I have several rackmount eventides (H3000, GTR4000, H8000FW), the H9’s have that ‘simply accessible’ nature about them that make effects plug-n-play easy for a wide range of use cases.
September 1, 2015 at 3:01 am #140374
salplant
MemberSkyWriter wrote:Hi! good question! I like your midi foot controller. I have four H9’s but haven’t put together a framework like yours to coordinate them. One suggestion I might have, that could have been taken care of with your pedal board, is the assignment of aux and performance switches for each of your H9’s. I see you have a pedal, and assume it’s configured as an expression pedal for one (or more) of the H9’s. For now, mine are ‘setup’ with no preset configuration. I’m also not using them with only a guitar. For me, it’s a piece (or several pieces) of studio gear for any use. Although I have several rackmount eventides (H3000, GTR4000, H8000FW), the H9’s have that ‘simply accessible’ nature about them that make effects plug-n-play easy for a wide range of use cases.HI! I’ve never owned racks but I can only imagine the sonic possibilities. I have to agree, the accesibiity of the h9’s makes me feel like I have the world at my feet sometimes lol.
Unfortunately the mastermind doesn’t really function well as a looper controller, and I wasn’t able to find a midi controller that functioned well as one with the h9 while doing presets/cc messages at the same time, so i use the aux controller mainly as a looper controller, (Stop, Reverse, Record), but is it possible to control multiple H9’s with just 1 aux controller?
September 2, 2015 at 1:33 am #140388
mwe
Participantsalplant wrote:Unfortunately the mastermind doesn’t really function well as a looper controller, and I wasn’t able to find a midi controller that functioned well as one with the h9 while doing presets/cc messages at the same time, so i use the aux controller mainly as a looper controller, (Stop, Reverse, Record), but is it possible to control multiple H9’s with just 1 aux controller?
Look at the XMT CC mapping. It lets you map an aux switch to CCs that the H9 will transmit. I don’t think it’s available via H9 Control, you’ll have to dig into the menus on the box. Then you’ll need to map the CCs to your desired functions on the receiving H9. I have an aux switch mapped this way to toggle active/bypass on 2 H9s, works great.
September 4, 2015 at 3:04 am #140411
salplant
Membermwe wrote:salplant wrote:Unfortunately the mastermind doesn’t really function well as a looper controller, and I wasn’t able to find a midi controller that functioned well as one with the h9 while doing presets/cc messages at the same time, so i use the aux controller mainly as a looper controller, (Stop, Reverse, Record), but is it possible to control multiple H9’s with just 1 aux controller?
Thank you, i’ll definitely try that out!
September 4, 2015 at 3:05 am #140412
salplant
MemberI was also wondering, is there a specific way I should be bypassing them? I have them at DSP + FX.
