I hear a bug in 9000
Home Forums Products Rackmount I hear a bug in 9000
Viewing 3 reply threads
    • #187651
      millertime
        in gorgeous delay when I turn up the Q factor knob up I get a hear popping skreech
      • #187652
        joecozzi
          To be helpful, can you tell us specifically which algorithm you’re working with, please? For the best troubleshooting, I recommend emailing a video to support@eventideaudio.com and explain your signal flow. Thank you.
        • #187653
          millertime
            algorithm is call gorgeous Delay #218 Im just running stereo 1 and 2, simple routing into metric halo
            Now that I’m going through delays the vintage delay #654 algorithm is way out of wack
          • #187680
              The Q factor is very extreme in this algorithm along with some of the other H8000 algorithms. I just tested and this behavior is the same on the H8000. I would suggest not turning up the Q on this algorithm, or using a different algorithm. ModFilter is a good choice for a dual filtered delay.
              The Vintage Delay algorithm loads with the LFO going very fast. Try turning the RATE parameter down to around 1-2 Hz.
