I hear gating on low input signals Equivocate
Home › Forums › Products › Plug-Ins › I hear gating on low input signals Equivocate
Viewing 7 reply threads
    • #115549
      deepg
        Is it just me or is there a gate on signals lower than th 60db in the input of Equivocate?
        It could be gating per band that is to save CPU or something. I just have to do a project with very low to very high volume changes.
      • #152877
        DGillespie
          There shouldn't be any gating on the EQ at all, it should pass signal at any level. There's a gate on the Match EQ functionality, where it won't try to match a signal that's too quiet, since in practice this just confuses the algorithm.  Is this what you're talking about?
          Thanks,
          Dan
        • #153028
          deepg
            False alarm, had time to find the plug that was gating was FabFilter Pro Q2 with a high pass in linear phase mode very high.
            If you want I can edit my heading of the original post.
            Thanks for looking into it.
          • #153029
            deepg
              hold that one.. a few minutes back.. still testing
            • #153031
              deepg
                ok so I am supplying screen shots of the problem
                here is the chain with MRecorder plugin capturing signals pre and post each instance of Equivocate.
                and the level normalised results of the captures.
                I am unsure why the mute/ gate occurs in the signal (see results marked in red)
                Please note this chain produces no gating when the input signal is higher, ie increse gain before plugin chain.
              • #153032
                deepg
                  BTW the pre normalised signal level post eq plugin 1 is -105db to -55db and the output of the second eq is similar but with the muted areas.
                • #165274
                  deepg
                    Culprit found!
                    Ableton Live mutes vst2 plugins when audio drops below -100dbfs.
                    Who knew right?
                    There is a fix (sort of) I’ll post here later the link but it involves creating or editing ‘options.txt’ and placing a time value that delays the muting of low signals BUT does not stop this behaviour altogether.
                    Took a few years to discover this. Sorry for thinking it was Equivocate.
                  • #165275
                    deepg
