Home › Forums › Administrivia › Website Discussion › I know nothing about midi!
- This topic has 5 replies, 3 voices, and was last updated 2 years, 1 month ago by
Eventide Staff.
January 27, 2024 at 8:40 pm #177771
How do you plug midi up? I tried through the midi ports but I had both of the port hook up but I don’t think it was right? Then I tried hooking up my foot pedal and it was always off the mark when it came to being calibrated right and I think I calibrated it right on the I/0. I’m so lost I guess I should just give up!
January 28, 2024 at 6:47 pm #177775
For 5 pin MIDI cables, plug the MIDI out of one device into the MIDI In of the other device. If you need bi directional communication, then you’ll also need a MIDI cable from the Out of the 2nd device to the In of the 1st device.
January 29, 2024 at 1:08 pm #177786
Please post your question in our stompbox forum with the following information and we can help you better:
- Which Eventide device are you trying to send MIDI too?
- What device are you using to send MIDI information?
- What are you trying to accomplish with this setup? (Load presets/programs, edit parameters, etc)
- What have you tried so far?
February 10, 2024 at 4:28 pm #178085
The Eventide H90. I am using the Morningstar MC6. I have tried loading everything I want to control onto my computer and Morningstar and it just seems not to work with anything. I have a Dunlop pedal and I can’t get the pedal to go to 100% it goes to 112% percent . I need to know how to fix that too sorry 🙁
February 10, 2024 at 6:50 pm #178088
Can someone tell me what the numbers are for all the effects on the Eventide H90???
February 12, 2024 at 9:51 am #178127
The H90 uses Program lists; each list has 99 Programs. Each Programs contains two presets.
You can send Program Change messages from your MIDI controller to load the different Programs on the H90.
It sounds like you may also need to calibrate your expression pedal: https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/system-menu/io.html
