June 7, 2012 at 9:01 pm #108827
I haven't seen one, but I'm having issues with what could be an unstable clock in my Roland VS2400 or my Eclipse. When connecting optical out of the VS to my Eclipse, I have to engage the Eclipse's SRC. Otherwise, the status shows as "drifting". But if I connect my Eclipse's optical out to the optical in of the VS2400, the VS keeps frequently (and not always immediately) stating "digital in UNLOCK". I'm guessing at this point it must be the VS2400 that has a dodgy internal clock. Just to put my mind at ease, is there a diagnostic on the Eclipse that tells me whether the optical i/o is working properly? I've only seen this kinda thing on a TC Electronic Finalizer.
June 7, 2012 at 9:41 pm #123528
Just a wild guess – are you setting the clock source of the Eclipse to "DigIn" ? The "slipping" indication usually only occurs when the clock source is set to something other than the digital input.
Similarly, if the Eclipse's clock source is not set correctly, its clock will be wobbly, making it hard for something connected to its output to lock properly.
June 7, 2012 at 10:53 pm #123530
Although the source and destination are 44.1k, the Eclipse needed setting to Digin44100hz. Sorted now.
June 7, 2012 at 10:57 pm #134610
It needs to be actually set, because the clocks will not be quite the same – if you have one 44.1 and another 44.1, there will be enough of a difference to get the dread "slipping."
