I/O Question
Home Forums Products Rackmount I/O Question
Viewing 3 reply threads
    • #105329
      I was wondering if I can use the light S/Pdif input and the coax S/Pdif output at the same time?
       Thanks
    • #116915
      Good question!
      I think you should try; I personally don't see why it shouldn't work, w/the correct settings, unless internal hardware limitations put a stop to this.
      Try setting DIG-IN to RCA and DIG-OUT>OPTICAL OUT to S/PDIF.
      best
    • #116921
       It works. It wouldn't have if it didn't have all the setting choices. Nice.
      So I can use that extra output I had sitting around and use the coax as a send to another effects unit that is coax only.
      Cool.
    • #127952
      Nice!
      from the User Manual:
      All of the digital outputs send live signals all of the time! However, they only
      send one protocol. Select that protocol under SETUP DIG-OUT FORMAT.
      Under (CS-TYPE) select Pro if you are primarily interested in using the
      XLR digital outputs, and Cns if you are primarily interested in using the
      RCA or optical (non-ADAT) digital outputs.
       Idea
