Home › Forums › Products › Stompboxes › I want a bypass patch
August 19, 2018 at 3:45 am #114902terichParticipant
I’m looking for a patch that does nothing and doesn’t color the sound at all. I know, sounds dumb, but I have two H9s controlled with a midi setup and I have it rigged so they toggle on and off together (makes controlling them live easier.) For a lot of songs, though, I only need one effect, so I need the other one to have no impact on the sound.
Right now I use a patch set to a flat EQ setting, but the high-end drops out quite a bit. Is there a good patch I can select that doesn’t do anything at all, and doesn’t color the sound in any way?
August 19, 2018 at 3:46 am #149949
If you save any preset when bypassed, and then load it from a MIDI PC, it will load bypassed. This may be what you need.
Ah, sorry, I should have specified I use one midi switch to toggle the H9s on and off, so even if I saved the effect off, when I hit the toggle the effect would kick in and then change the tone.
August 20, 2018 at 4:07 am #149952terich wrote:
I should have specified I use one midi switch to toggle the H9s on and off, so even if I saved the effect off when I hit the toggle the effect would kick in and then change the tone.
Off the top of my head, maybe the Looper algorithm? It might not work but worth a try.
Set the MIDI mapping for "Toggle between active and bypass" instead of "Left Footswitch" because the Left Footswitch can trigger Recording
August 20, 2018 at 4:08 am #149953
Or SpaceTime with Mix of 0?
