I want the reverb tail to carry over when I disengage the Blackhole pedal
Home › Forums › Products › Stompboxes › I want the reverb tail to carry over when I disengage the Blackhole pedal
    • #164936
      peteycorn
        Hi.  I’m brand new to the forums, and I have only had my Blackhole pedal for a little over 12 hours.  I love it, but I would love it enormously more if the reverb tail carried over after I disengage the pedal.  I have a Boss RE-2 Space Echo that has a small dedicated switch on the back labeled “Carry Over” that allows for this feature to be turned on or off as desired.  Is there something in the software that will allow me to set that up?  I haven’t tried to update the pedal software because it seems to be working alright so far.  I’ve read that some pedals need to be updated to fix a bug.
        Thanks
        Petey
      • #164938
        joecozzi
          Hi Peteycorn,
          If you enter System Settings by powering up the pedal with the active ftsw and page button pressed, the active LED button switches between the different bypass modes. Check this out this video at 10:52: https://m.youtube.com/watch?v=0xcWsiw3Wqc&list=PLhT2MsSeKiDxicpl2QOj2oLnX21tzwK4Y&index=9
