Home › Forums › Products › Rackmount › IF/Could it be done?
If the Eclipse inherited the Ultrashifter algorithm, could running two Eclipse units together effectively produce the same result as an H8000?
No, because it needs close coupling between the units. Sorry.
If you want more algs or Ultrashifter, you need an H8000.
