If the H9 will only be available as Max version…
Home › Forums › Products › Stompboxes › If the H9 will only be available as Max version…
Viewing 6 reply threads
    • #116220
      Boynigel
        …does that mean that as a current owner of a 7-year-old Max, that if mine were to fail I’d have to spend all that algorithm money all over again?  Would be cool if there was a special “Core” replacement price for registered Max owners if faced with this situation.
      • #156468
        Fender17
          +1 Good point.
        • #156470
          rograt
            I wasn’t aware of this but wouldn’t this pave the way for a general price reduction of what is after all quite a “mature” product now?
          • #156480
            leovooijs
              You could order a replacement core now, jus in case 😉
            • #156517
              Boynigel
                Can anyone from Eventide please weigh in here?
              • #156518
                joecozzi
                  Technically, if your Max were to malfunction you would not lose all your algorithms on your account. You could find a used Core unit and still take advantage of the fact that you can transfer Max algorithms to up to four H9 Core or Standard units on your account.
                  Moreover, because we are continuing to support all H9 models despite the Core and Standard versions being discontinued, in a high percentage of cases, servicing any H9 would cost way less than buying a new H9 anyways.
                • #156528
                  joecozzi
                    It varies widely depending on how busy we are, the type of repair, available parts, and shipping times. That said, Average – 1-2 weeks
                  • #156527
                    Boynigel
                      joecozzi wrote:
                      Technically, if your Max were to malfunction you would not lose all your algorithms on your account. You could find a used Core unit and still take advantage of the fact that you can transfer Max algorithms to up to four H9 Core or Standard units on your account. Moreover, because we are continuing to support all H9 models despite the Core and Standard versions being discontinued, in a high percentage of cases, servicing any H9 would cost way less than buying a new H9 anyways.
                      What’s an average turnaround time to get a H9 repaired though?
