Improvement of rotary algorithm request
Home Forums Products Stompboxes Improvement of rotary algorithm request
Viewing 24 reply threads
    • #112229
      harmamusic
      I recently compared the H9 rotary to the Neo Ventilator II and the Neo Mini Vent to the Axe Fx II, Mobius and Mini Vent. The Neo instrument pedals are top of the line for rotary simulation IMO. I did think that the H9 rotary algorithm was the best of the other pedals/multi-effectors so I would like to ask if Eventide would consider improving the algorithm? Possible additions/changes:
      – Adding a drive control to get the tube like breakup like a real leslie (122)
      – Improving the phasing/3D aspect of the rotary sound. I tried the Giant setting but for me it makes the HI (horn) seem too shimmery.
      – Improving the Fast/Slow ramping up/down and the Brake (stop)
      Here are the video's I created for reference:
      [View:https://www.youtube.com/watch?v=O8eOFRu2oBY&list=UUIMDyg6oYgNSI1SF8eHptSg:550:0%5D
      [View:https://www.youtube.com/watch?v=mH_KPh3v_vE&list=UUIMDyg6oYgNSI1SF8eHptSg:550:0%5D
      [View:https://www.youtube.com/watch?v=CG7-iKKA0oo&list=UUIMDyg6oYgNSI1SF8eHptSg:550:0%5D
    • #127317
      harmamusic
    • #127328
      Bodde
      The links work Harry. Very good compare videos! Have to agree that the Neo beats them all.
    • #137972
      harmamusic
      Thanks bodde. It would be very cool if Eventide could improve the algorithm.
    • #138015
      sugabear2133
      I second this motion!
    • #138016
      gkellum
      Thanks for posting those videos Harry. I sent them on to the DSP engineer that developed the Rotary algorithm for him to consider.
    • #138019
      harmamusic
    • #138020
      Bodde
      Good news and thanks!
    • #138209
      dimitris1179
      My Modfactor likes the idea of an updated algo (and my H9 too)! Cool
    • #138265
      cbm
      I hope he/she is inspired. The Rotary is the rare Eventide algorithm that it good, but not great.
    • #127574
      iliaspap
      +1   An inproved (more 3D like Ventilator and Strymon Lex) rotary algo for the H9 would be awesome!
    • #139685
      dimitris1179
      Is there anything new about this?
    • #139758
      dimitris1179
      Ok, so it was perhaps a little politically incorrect to ask you about a new “feature” the day that you released an important firmware update. The question is still valid however, and even a small hint will be more than fine (working on it, considering it, frozen, low priority etc….).
    • #139759
      Sorry – we really can't say (or even hint) anything about future releases until they are very close. (Too many variables, and endless abuse if things get delayed).
      For now, all I can say is that the request has been noted.
      • #139837
        iliaspap
        These are awesome news. H9 is killer in Delays, Reverbs, but the modfactor algos need some impovements, competitors are ahead in this section. Rotary is one of them, both Lex and Ventilator are more organic and 3Dimenional.
        A real univibe would be great addition in the mod-factor algos also.
        Thanks for the support and congrats for the latest update, great additions indeed!
    • #139820
      Hi, please someone can me suggest how I have to setting rotary on mod-facor to obtain a guitar effect like that of David Gilmoure on breathe (dark side of the moon – rhitmic guitar)? I’m trying to do it, but I don’t be able….
      Thanks in advance for your support,
      Roberto
      • #139830
        joinpobob
        Roberto, here is what I use for Breathe (great song, btw).  I hope you like it.  I use the phaser algo, not the rotary.
        OP, I agree, the Rotary Algo could use an update.  I really like to use Rotary sounds when I can get it to sound good.  The best I have gotten so far is to use one H9 on rotary and one H9 on Comp/EQ “telephony” preset.  That gets me some of the Leslie-sounding distortion.
        Best,
        RS
        Roberto
      • #139849
        marcusm750
        This is exactly what I do with my ModFactor and H9 to lo-fi the Rotary algo and remove some of the high-frequency sheen.  In fact, this also works well with Crystals and Shimmer to remove some of the down-right shrill at times (but for these I open up the low end in the telephony preset).
    • #139873
      st.bede
      I also stack some algorithms to get a little deeper and more organic sounding univibe.
      • #139875
        marcusm750
        In my pursuit for a more lumpy, lopsided and hippy-trippy Uni-Vibe, I tried stacking an MXR Phase 45 into my ModFactor running the Lou-nivibe (12:2) preset.  The results were less than spectacular: when they swept together, it was awesome; but when they swept against each other, it quickly became a muddled mess.
        Now that I also have an H9 with the Phaser algo, I should try stacking two Lou-nivibes with their tap tempos sync’ed via MIDI to see how this would work.
        What algo(s) do you stack with the Lou-nivibe or your own Phaser preset to achieve a “more organic” Uni-Vibe?
      • #139890
        st.bede
        It was a awhile ago and since then I have pulled off my board two of my factor pedals. Basically my board was crammed and I wanted to put a different pedal on. I was not going for a full univibe sound but i did get more depth and trippyness. I do not look at Eventide as a replacement of my fav pedals but more as a extremely functional and great sounding choice. Just like my PRS will never replace my Gibson and Fender guitars. My PRS has its own sound and that is why I have it. Having said all that I would like a better univibe sound. If I get a chance I will pull out my other eventide factors and see what I stacked.
      • #141496
        st.bede
        I have not read or thought about this in a long time. I am again running my MF with  my TF. I will take a look.
    • #141286
      air621
      Just trying to keep this alive. I wish the rotary effect had drive control similar to a Leslie.
    • #141506
      rck
      I’ve spent quite a few hours working with the Rotary Algo on the H9, and while it is good, I have not been very successful addding “drive” to it (with clean boosts, EQ, Comp and OD pedals) to simulate that “throb” that some other Rotary pedals have.
      A little tweak to the exisitng Algo would be really, really useful (and very much appreciated) and would eliminate the need for another companies Rotary pedal.
      Thanks Eventide for the consideration.
    • #142340
      iliaspap
      So.. no improvment in Rotary or any other Mod algorithm of H9 in 2.6.0 update..
    • #142796
      dantahoua
      I add my voice for the improvment of the Rotary algorithm… Everything that was said in the first post is exactly what it must be done! 🙂 Driver, better 3d, better ramping…
    • #143579
      dagjonas
      Just keeping this alive, waiting 🙂
    • #148138
      llemtt
      Yesterday I bought the rotary algorithm… great!!
      But it surely needs little improvements…
      +1
    • #152258
      lemonengine1
      +1 Would be great if you could assign the fast/slow “performance” switch functionality to one of the aux switches.
    • #152260
      camn
      You can totally use the Aux switch as a performance switch.
    • #158661
      vseager
      Drive feature for true lesley tube breakup would be great!
