In app purchase disabled?
Home Forums Products Stompboxes In app purchase disabled?
Viewing 7 reply threads
    • #111996
      tenohr
      I suddenly cant purchase new algorithms from my H9 app. The message says in app purchase is disabled on this device, but I have no restrictions on my iPad.
      What is happening?
      Terje
    • #126825
      tenohr
      Ahh… The Ghost of iOS8. Everything's ok now…
    • #126826
      tenohr
      Sorry. iOS8 problem. Fixed!
    • #126827
      gkellum
      I just tried it on an iPad here, and purchasing algorithms appears to be working fine.  Could you double check the restrictions on your iPad set under Settings / General / Restrictions?  If everything there looks good, could you let us know what version of iOS you have installed and what generation of iPad you are using?
    • #126843
      sandris
      Same here. iPad Air, iOS 8.02.
      sandris.
    • #126844
      gkellum
      sandris:
      Did you double check the restrictions on your iPad set under Settings / General / Restrictions? I'm not sure if that's how tenohr fixed his problem or not. If that doesn't work for you let us know, and perhaps tenohr will chime in and let us know what he did to fix his problem.
    • #137467
      sandris
      Strange, restrictions was disabled, but I did enable and then disable again. Now it's working! 🙂
    • #137468
      gkellum
      sandris:
      Thanks for letting us know in case that comes up again with someone else. That's strange indeed.
