in ear – Mix in H90
Home Forums Products Stompboxes in ear – Mix in H90
Viewing 4 reply threads
    • #177060
      lausens1
      Hi, I am new here… after having watched Nate Navarro use his H90 on bass I am pretty convinced that I shall sell my HX Stomp. A Killer-Reason-For-Purchase would be if I could plug both my bass-guitar (mono) and the stereo-In-Ear-Mix into the H90. Then hand over just my bass-signal to FOH and listen to my bass-signal plus the In-Ear-Mix through my Headphones. Is that possible to route in H90?
      Thank you so much in advance and happy new year!
      Yours, Alex.
    • #177067
      joecozzi
      It is possible to combine your bass signal and a stereo in-ear mix with the H90, but since the pedal doesn’t have a headphone output, you’ll have to send the signal out of the H90 into another headphone amp to be able to monitor it.
    • #177076
      lausens1
      Oh, thank you so much for your quick reply! I will buy it now! Could you explain to me how I should program that? Thanks in advance!
      Yours, Alex.
    • #177078
      joecozzi
      Before I get into specifics, what is your aim with this configuration? Do you want to process the bass with effects? Do you need to process the in-ear mix with effects? Do you need the H90 to act as a splitter for your bass signal?
    • #177097
      lausens1
      My plan is to process the bass and hand the processed signal both to FOH and addd ist to my inner-mix. The latter is supposed to be the exact signal from the mixer and does not have to be processed in any form…
      Thank you so much!
