This is easily adjusted in the system settings using H90 Control. Click the Pedal tab > General Settings > Preset Range. Here you are able to customize the number of presets that are shown. Set First Preset to one and Last Preset to 99 and you should be good. Assuming you have an H9 Max, if for some reason you don’t see 99 presets available you can download the factory lists off the H9 website on the Downloads page.
