June 14, 2017 at 12:29 pm #114225gruversmMember
Since updating to MacOS High Sierra, the 2016 Stereo Room plug-in is labled as “Incompatible” and is blocked when using Logic Pro X. Is this a known issue and/or workaround?
June 14, 2017 at 3:16 pm #146628
Hi-
We currently only support macOs Lion thru Sierra, given that High Sierra is still in dev beta. However, we are beginning the process of testing our products on High Sierra, and will look into addressing this.
-Tom
June 14, 2017 at 8:24 pm #146630gruversmMember
Thank you Tom.
October 13, 2017 at 11:21 pm #147413Lordtom09Participant
I just purchaed the Quadravox but not seeing the plugin in logic 10.3. Help
Hi-
This is a known issue with all AU plug-ins on High Sierra. Try restarting your Mac and they should reappear.
-Tom
October 16, 2017 at 3:18 pm #147431
Also as an aside, we've confirmed that all of our plug-ins work fine on High Sierra, except for one small bug – the preset dropdown menu is not alphabetized. We have a fix for this which will be released shortly.
November 9, 2017 at 5:03 pm #147614Weird MusicParticipantTLongabaugh wrote:
Also as an aside, we’ve confirmed that all of our plug-ins work fine on High Sierra, except for one small bug – the preset dropdown menu is not alphabetized. We have a fix for this which will be released shortly.
Correction: H910 AU High Sierra UAD version is not working.
Kind regards
Kind regards
We've since gotten reports of this, and are looking into it. Thanks!
February 19, 2018 at 2:54 pm #148474startappMember
Dear Sir, or Madame,
I am an owner of H910, purchased by Universal Audio. I tried to opened it in Logic X, as a midi controlled effect as well as an instert plugin in a bus, however it does not work at all. Can You tell me if there is still any issue? I have Logic X 10.4.0 as well as High Sierra. I checked this plugin in Maschine 2.0 DAW and it was working fine as an insert plugin. However for Logic it does not work at all.
Thank You very much in advance for a reply.
Wojciech
Wojciech
Hi Wojciech,
The known issues with the AU version of the H910 for UAD should be fixed in the UAD 9.5 release from last week. Can you make sure you're running UAD 9.5?
Thanks,
Dan
