infinite repeat with reverse.
Home Forums Products Stompboxes infinite repeat with reverse.
  • This topic has 2 replies, 2 voices, and was last updated 2 years ago by joecozzi
    • #167105
      bangebalbob
      it’s seems like each time a press phi for reverse delay the infinite repeat function stops working even when hotswitch is still active.
      is there anyway i can keep the loop untouched with reverse function?
    • #167106
      bangebalbob
      here you can see that the loop starts to fade out to quiet as soon as phi is pressed, but it stills plays in the background, so it’s as if the loop is in hold mode as it should be but somehow the pedal won’t hold it on the initial sound level.
      https://youtube.com/shorts/fCBhHXIEsK0
    • #167173
      joecozzi
      Hi bangebalbob, unfortunately, the reverse feature with an infinitely delayed signal is not possible.
