Input gain instead of effect mix for delays
Home Forums Products Stompboxes Input gain instead of effect mix for delays
    • #111152
      I think it would be more useful for delay effects to have an input gain control versus current effect mix control.
      You could have smooth delay fade in and fade out with trails using input gain control on expression pedal.
      For example if you would play reggae rythm and you want to bring a long delay only on  the last note of the bar and continue the rythm. Don't know if i'm making myself clear here. You want delay to catch only the last note using expression pedal. Input gain would work great here, and now you can't do that with effect mix.
    • #124912
      gkellum
        Thanks for the feedback.  I added your comment to our list of algorithm suggestions.  We'll discuss it next time we go through the list.
