March 27, 2011 at 11:19 pm #107752
Hi Guys I have 2 questions regarding the Eventide H8000FW.
1) I am using an external Synth (Virus TI2), connecting using unbalanced mono cables from the synth to the analog Eventide inputs 3 + 4 (1/4 inch plug), the synth volume is all the way up.
the Eventide metering on the input shows at max about -12.
Is that ok ?
2) I connected a MIDI cable from Eventide Midi Out to an external device (Creamware Pulsar Card), I open a Midi channel inside Cubase5.5 and choose on the output "Eventide Dice"
When i play my keyboard i can see that the "Busy" light on the Eventide is working so the Eventide receives the signal but I cant get any Midi signal on the Creamware card.
Any Idea why the eventide is not sending any notes ?
Thank you very much
Tomer.
March 28, 2011 at 3:48 pm #121810
Tomerttb:
Is that ok ?
Probably. You could adjust the "PreA/D Gain" to increase it a bit. (UM p.73).
Tomerttb:
I have a pretty good idea. The "Eventide Dice" (FireWire MIDI in this case) is an input to the unit, not a source for the MIDI out connector The MIDI outs are only used when the H8000 itself generates MIDI.
March 28, 2011 at 9:39 pm #121813
Thank you Ni
1 – Understand and work perfectly.
2 – I understand, do you think I can use the through ? sending the Midi notes on the FW to the unit, and let them continue to the next hardware using the through ?
Thank you Tomer.
March 28, 2011 at 10:30 pm #133025
Sorry. The FireWire MIDI and the DIN5 MIDI are entirely separate, so you can't use the unit as a FireWire MIDI interface for external equipment.
March 28, 2011 at 10:42 pm #133026
Thank you
Tomer.
