Home › Forums › Products › Stompboxes › Insert Location Setting Help
- This topic has 3 replies, 2 voices, and was last updated 2 years, 2 months ago by
joecozzi
Eventide Staff.
January 16, 2024 at 1:25 pm #177421
Question for all you H90 scientists out there. When using another pedal routed in / out of the H90 as an insert, are you able to set the location of that insert differently per preset (and have it therefore be midi foot-switchable), or will the insert location setting be Global only? Some better context: I want to run a Strymon Timeline in / out of the H90 insert in stereo. For convenience I like to make H90 / Timeline presets and switch between them with a little Morningstar midi switcher. So say I have a preset where the H90 is running a chorus on A and a reverb on B, and I want the Timeline to be placed between those two effects. Then I switch to another midi preset, where I have the H90 running a drive on A and a tremolo on B, so I want to have the Timeline be placed after B. Can that insert location be programmed PER PRESET, or is that location a global-only setting? To those of you who respond with some helpful insight as opposed to being the “how about read the manual bro” guy, I thank you in advance!
January 16, 2024 at 1:48 pm #177424
When using another pedal routed in / out of the H90 as an insert, are you able to set the location of that insert differently per preset (and have it therefore be midi foot-switchable), or will the insert location setting be Global only?…Can that insert location be programmed PER PRESET, or is that location a global-only setting?
Yes, insert position is stored on a Program basis as you described. There is no global setting for inserts, only routing modes.
January 16, 2024 at 1:58 pm #177427
First off, thank you for clearing that up for me, huge help. Secondly, I hope your users appreciate how surprisingly fast and informative your support is for your products. I personally have not dealt with another company who can compare in that regard. Thank you again.
January 16, 2024 at 2:08 pm #177428
Very I kind of you to say that. We appreciate it. We’re grateful to have users like you that contribute to the forum and add to the overall knowledge base.
