Insert volume affected by program wet/dry value
Home Forums Products Stompboxes Insert volume affected by program wet/dry value
    • #183365
      unguitar
        I’ve set an insert before the preset blocks, mixed at 50%.
        How comes that when I change the program mix to dry (0% effect) the insert signal is not routed to the output?
        thank you
      • #183368
        tsternfeld
          The insert chain is part of the wet path of your program.  If you set your program mix to fully dry, that is essentially the same as DSP bypass, so the inserts will also be bypassed.
          If you want a different behavior, you will need to instead work with the Insert Mix and individual A/B bypass and mix.
        • #183369
          unguitar
            that’s a pity!
            this is a strong limitation for using the H90 as a mixer/router.
            I know this isn’t its purpose but it’s tempting making the best of its 4 ins/outs
