Installation of 2.1.14.144 hangs?
Home Forums Products Rackmount Installation of 2.1.14.144 hangs?
Viewing 9 reply threads
    • #173217
      kims
        Hi
        I started updating to 2.1.14.144, from 2.0.7(120), for about over 10 minutes ago, and its still at 0% – is that normal ?
        if not, what do I do now ? i dont a brick H9000
      • #173218
        kims
          Its stopped at “Preparing to install..” still at 0%
        • #173219
          kims
            I could not close Emote, so I restartet windows, i can not connect to emote now….
          • #173220
            kims
              ahhh fixed it..phew
            • #173223
                Sorry for the issues you had. This may have been a small hangup with the update being downloaded from the network.
                The update process designed in a way that should not brick your H9000 if it it gets interrupted. There is also a recovery mode option of something goes wrong with the update.
                Hope you enjoy the update!
              • #173395
                joeydego
                  ahhh fixed it..phew
                  How long was your H9000 on before you tried to update? I find leaving the H9000 at idle for many hours causes some instability sometimes.
                • #173397
                  kims
                    tbskoglund:
                    I read the similar thread regarding the beta hangs, so i took the chance and just rebooted 🙂
                    joeydego:
                    under 5 min´s
                  • #173401
                    zengomi
                      Should Emote be updated before attempting this firmware update?
                      • #173403
                          Yes, that’s the best way to do it.
                      • #173404
                        zengomi
                          To answer my question, no. At least, that worked for me just now. So time to update Emote.
                        • #173405
                          zengomi
                            Henceforth, Emote first, as you recommend. Thanks.
                            • #173406
                                You’re welcome. Either way will work as you found, but it’s recommended to update Emote first.
