Instant Flanger v1.1.2 (VST) not showing up in Ableton Live
Home Forums Products Plug-Ins Instant Flanger v1.1.2 (VST) not showing up in Ableton Live
Viewing 3 reply threads
    • #115268
      Phase47
        iLok is fine. The AU shows up in Logic. No VST of Instant Flanger in Live however. I’ve rescanned the VST folder, but no luck. I’ve also verified that the VST in the correct Library folder on the HD. Other plugins all fine, Eventide Instant Phaser, Black Hole, etc.
      • #151665
        tlongabaugh
          Hey, sory to hear that you're having issues with IFmkII in Live.
          Can you try opening Live -> Preferences -> File/Folder, and then Option-click "Rescan plugins". That'll prompt a deep rescan.
          • #151666
            Phase47
              tlongabaugh wrote:
              Hey, sory to hear that you’re having issues with IFmkII in Live.
              Can you try opening Live -> Preferences -> File/Folder, and then Option-click “Rescan plugins”. That’ll prompt a deep rescan.
              Hi. Yes, I mentioned that I’ve rescanned in the inital post. No luck.
            • #151669
              tlongabaugh
                Hi. Yes, I mentioned that I've rescanned in the inital post. No luck.
                Yes, but the option-click is important beyond just clicking "Rescan", which is why I mentioned it. Try the following:
                • Close Live
                • Uninstall the VST, by removing it form Mac HD/Library/Audio/Plug-ins/VST.
                • Open Live, rescan your plugins, and shut Live.
                • Reinstall the VST using the installer
                • Open Live
                Let me know if that doesn't do the trick. Also, please let me know what version of Live and macOS you are using.
            • #151670
              Phase47
                The deep scan didi the trick! I missed the “option” in your first reply – thanks so much for your help. Safe to close this on out as solved.
              • #151673
                tlongabaugh
                  Awesome, enjoy!
