November 6, 2016 at 12:24 am #113801
JRMac
MemberI recently installed the 2016 Stereo Room reverb from Eventide. I downloaded the iLok License Manager and validated my license on line. It was working fine, so I disconnected my PC from the internet. The next time I tried to use the plugin I got the massage:
“The software required to validate the license for this product is not running. Please install the product or download and run the iLok License Manager.”
I put my PC online again (not an easy thing to do), downloaded the iLok License Manager again (since there appeared to be an updated version), and the plug in was working fine again. So I put my PC offline. That was last week. Today I tried to open the Eventide plugin again and got the same message.
So far, once I turn my PC off and disconnect from the internet I don’t seem to be able to use the Eventide plugin, even though it is working fine immediately after I validate the license.
I’m using Windows 10 Pro, 64-bit, and my plugin host is Ableton Live. I’m not using the iLok manager for any other products. Can anyone help?
November 6, 2016 at 10:23 am #144809
mat herbert
ParticipantIt’s the iLok manager sofftware timing out before it gets a chance to load properly… i get it from time to time and i know of a few others personlly who also experience it.
on the windows task bar click start, then type ‘services’ (forget the quotes) into the ‘search programs and files’ box and hit return.
Scroll down to PACE Licence Services, highlight it and in the top left click on ‘start’.
That should sort you out till it happens again, just repeat the above if/when it does.
November 8, 2016 at 12:07 am #144828
JRMac
Membermat herbert wrote:It’s the iLok manager sofftware timing out before it gets a chance to load properly… i get it from time to time and i know of a few others personlly who also experience it.
Hey Mat,
Many thanks for your reply. Windows 10 doesn’t have the task bar with Start. But I turned on “Show hidden files/folders” and searched for “Pace License Services”. It returned no results. When I searched for “Pace” the following folder turned up:
PACE>Services>License Services>LDSvc
I right clicked on the application file LDSvc and chose “Run as administrator”. Got the message: “Do you want the app to make changes?” Clicked Yes. A pop-up window appeared just for a fraction of a second. Restarted my PC. Opened Live. Rescanned my plugins just in case. Tried to open the Eventide plugin and got the same message as in my original post.
Many thanks for your suggestion buddy. It sounded spot on, and was definately worth a try.
JR
November 6, 2016 at 2:22 pm #144811
Hi JRMac, I've not seen this on my PC or heard of it, but it does sound like the iLok License Manager service is crashing or hanging. I wonder if it happens again if a simple reboot, or logout and login with fix it.
In the meantime I'll contact PACE and see if they've heard of this issue and are working to address it.
Sorry for the problems,
Dan
November 8, 2016 at 12:16 am #144829
JRMac
MemberDGillespie wrote:Hi JRMac, I’ve not seen this on my PC or heard of it, but it does sound like the iLok License Manager service is crashing or hanging. I wonder if it happens again if a simple reboot, or logout and login with fix it.
In the meantime I’ll contact PACE and see if they’ve heard of this issue and are working to address it.
Dan
Hey Dan. Many thanks for your reply. No, I’ve tried turning off and on my PC several times, with the same result. I’ve also tried Mat’s suggestion (above). No luck there either I’m afraid.
November 8, 2016 at 10:31 am #144832
mat herbert
ParticipantHi Dan!
If you contact Pace you’re likely to get the same answer i did as that’s what i posted above… you can try to extend the timeout period by right clicking on the PACE entry in task manager, click ‘properties’ and try setting startup type to ‘Automatic delayed start’ to see if that helps, again this is from Pace….
If that doesn’t remedy it permintently then occasionally you’ll have to start it manually as i originally described.
hth!
November 8, 2016 at 2:38 pm #144834
mat herbert
ParticipantSorry to hear that JRMac, i’m still on win7 64bit and did not realise they’ve done away with the services function in win 10.
Hope you get it sorted mate as it’s clearly a major frustration!
I’ve heard of many others getting the issue on win7 and that fix has always sorted it for the people i’ve passed it on to.
November 8, 2016 at 5:53 pm #144835
Strascak
ParticipantJRMac:
I’m also on Windows 10 Pro x64. I have had intermittant problems with PACE when installing new software plugins.
Try this:
1. Go to the Taskbar and left click in an open area.
2. Select “Taskmanager”.
3. At the top of the Taskmanager window, select the “Services” tab.
4. Scroll down the list and only highlight, ” PaceLicenseDServices”
5. Left click on ” PaceLicenseDServices” and select “Open Services” from the menu.
6. In the new “Services” window, highlight “Pace License Services”.
7. Left click on “Pace License Services” and select “Properties” from the dropdown menu.
8. In the Pace License Properties Window, click on the dropdown in the middle of the window called “Startup Type” and select “Automatic (Delayed Start).
9. Below the “Startup Type”, ther is a “Service status:” area on the same window. Click on “Start”. The service should start.
10. Lastly before closing the “PACE License Services Properties” window, click on “Appy” and then close the window.
You might be asked to restart Windows but the “iLok License Manager” should work without a reboot.
NOTE:
If when you reboot and the “iLok License Manager” will not work, it might have been turned off. Just go to the “PACE License Services Properties” window, and click on “Start” and “Apply” again.
I have noticed some plugin installers reset the “Startup type” to “Automatic” only which causes the Pace service to stop.
I know it’s a pain but this has worked well for me on Win 10 x64.
Kevin
JRMac wrote:I recently installed the 2016 Stereo Room reverb from Eventide. I downloaded the iLok License Manager and validated my license on line. It was working fine, so I disconnected my PC from the internet. The next time I tried to use the plugin I got the massage:
November 9, 2016 at 2:29 am #144838
JRMac
MemberStrascak wrote:JRMac:
Try this:
NOTE:
Kevin
Many thanks Kevin. That solved the problem. After following your instructions I turned my PC off and on again just to be sure, and the Eventide plugin loaded fine. The good thing is, from my point of view, that I don’t need to put my audio PC online to use the same solution if the problem arises again in the future. Thanks for taking the time to post such detailed instructions my friend, much appreciated.
JR
November 9, 2016 at 4:19 pm #144840
Thanks Mat and Kevin for the solution!
November 9, 2016 at 5:28 pm #144842
Yes, thank you Kevin. I will forward this to PACE so they are aware of this issue for some users.
November 9, 2016 at 7:14 pm #144844
Strascak
ParticipantNo problem, I believe PACE is aware of this. I found a similar solution for Windows 7 on the PACE site. Unfortunately I had to adapt their solution to Windows 10.
Glad it solved your problem
Kevin
December 1, 2016 at 1:45 pm #145002
ChamomileShark
ParticipantI’ve had the same issue with ilok manager (ie not the dongle version)- it started when I installed the new version (the one before the current one).
I’m really not au fait with this stuff – do you need to uninstall the old ilok manager before installing the latest version?
December 1, 2016 at 3:59 pm #145004
No, you should be fine to just install the latest version of iLok License Manager. The installer should take care of updating everything correctly.
December 1, 2016 at 4:18 pm #145007
ChamomileShark
Participantok thank you. I guess there must have been an issue with the previous version. I’ll go and update it now. many thanks
