iPad cabled connection to Timefactor
Home › Forums › Products › Stompboxes › iPad cabled connection to Timefactor
Viewing 3 reply threads
    • #113864
      Phil_Blaich
        I’m trying to get the H9 software for ipad to work with Timefactor. I bought a $39 Lightning to USB “B” type cable by iconnect and the software is not seeing the connection. I beleive it’s a iPad 3 and using 10.1 OS. I can’t find anything in the manual, on-line or previous posts on this subject.
        What am I missing?
      • #145086
        gkellum
          We recommend using Apple's Camera Connection Kit to connect Factor pedals to iOS devices.  We've tested that set-up with all of the Factor pedals and even using USB hubs to connect multiple Factor pedals, and it works as expected.
          We don't have any experience with iConnect, and I'm not sure if that device when connected to a Factor pedal will cause the Factor pedal to appear as a MIDI device on an iOS device.  It likely doesn't work that way and is likely the cause of the problem you're having.
        • #145089
          Phil_Blaich
            I have not found that cable that has the “B” connector. Can you recommend anything?
            Thanks.
          • #145090
            gkellum
              It's this one:
