Home › Forums › Products › Stompboxes › iPad is not recognizing multiple H9s
July 25, 2014 at 3:49 pm #111810
gkellum
ParticipantFog_ducker:
My H9 and core are not connecting together with my ipad? They will individually, but whatever one I connect first becomes my only option? On the ipad itself, it shows that they are both connected in my settings, but the Bluetooth icon only engages on one pedal?
What model of iPad are you using and what version OS is installed on it? BadMelonFarmer mentioned on thegearpage that he wasn't able to connect more than two H9s at a time to his iPad Air, but this is the first time I've heard of someone not being able to connect more than one H9 at a time. -
July 25, 2014 at 10:02 pm #126396
fog_ducker
ParticipantI am also using an iPad Air. Version 7.1.2.
July 25, 2014 at 10:14 pm #126397
gkellum
Alright, thanks, we'll have to try with the same set-up and see if we can reproduce this…
February 28, 2019 at 3:13 am #151397
KevinFreud
Memberhave your issue is fixed? iPad 1st generation model can’t connect more than two H9s at the same time.
February 28, 2019 at 1:40 pm #151400
daviddb
ParticipantJust to reinforce this, I’ve only ever ONCE managed to get 2 H9’s connected simultanously on Bluetooth, and I’ve tried using iPad and Mac Pro. I’ve ended up doing my preset programming with one H9 connected via iPad and the other one via my Mac.
July 26, 2021 at 12:51 pm #158290
Johnas
Memberdaviddb wrote:Just to reinforce this, I’ve only ever ONCE managed to get 2 H9’s connected simultanously on Bluetooth, and I’ve tried using iPad and Mac Pro. I’ve ended up doing my preset programming with one H9 connected via iPad and the other one via my Mac.
Daviddb try this:
I want to confirm the above with a slight variation on the above mention workaround,in which in my case i dont press IGNORE
at the first pop up,
1.forget this network on all other bluetooth connected devices
2.Power up the 2 H9s
3.Have them both on a not connected status
4.press connect to the 1st device watching the 2nd blue Led on the pedal.
5.When the second blue Led lights up and the status on ipad shows connected,
6.press quickly connect to the second device,before the 1st pop up window
7.When the 1st pop up appear do nothing it will disapear and soon after a 2nd pop up window appears for approval.
8.Press Allow and watch that the second blue Led on the second device is light up and the Ipad tab sows connected.
9.You now have both units connected .Voila!
IOS 12.8
Ipad Air1
2xH9
March 11, 2019 at 4:36 pm #151468
skywriter
ParticipantIIRC At one time there was an Apple Bluetooth connection implementation that manifested as a limit on H9’s of 3 for 32bit iPads, and 1 (or 2?) for 64 bit iPads. Eventide contacted apple about this, but I don’t remember a resolution. FWIW, I use a gen 4 ipad with USB to connect to 5 H9’s because of the limit I had to use 2 iPads when I connected with Bluetooth.
