Home › Forums › Products › Rackmount › iPad remote control app for Eclipse, H series, DSP series and Orville.
- This topic has 16 replies, 2 voices, and was last updated 1 year, 4 months ago by
mishik.
November 8, 2015 at 5:38 pm #113008
Hi Guys,
Thre is a new version Eclipse remote control app that supports the Eclipse, DSP series, the H Series and the orville as well.
On an iPhone only the Eclipse is supported.
http://iosaudio.co.uk/IOSAudio2/EclipseRemote.html
https://itunes.apple.com/gb/app/eclipse-remote-control/id814413514?mt=8
Thanks
Andy
November 9, 2015 at 3:43 pm #141478
Thank you for creating something so helpful! Am I correct in understanding that if I have a MIDI interface for my Mac, I can use my iPad or iPhone to patch through the Mac and eventually send the commands to my Eclipse via Bluetooth or some other software interface?
November 9, 2015 at 4:38 pm #141481
As long as your iPad/iPhone is connected via WIFI to the same network your Mac is on then it will work using network midi.
You can download the manual here to have a look how to set it all up: http://www.iosaudio.co.uk/IOSAudio2/Support_files/EclipseManual.pdf
The iPhone version only supports the Eclipse, the iPad version supports the H, DSP and Orville.Thanks
Andy
November 9, 2015 at 4:42 pm #141482
Sorry I should have mentioned that bluetooth should work as well.
November 9, 2015 at 5:14 pm #141486
Thanks again, Andy! I’ll take a look at this today!
You’re efforts to create such a tool are really appreciated.
May 26, 2016 at 3:14 am #143443
Is there an Eclipse control app that works on a MacBook Pro, or is it iPad only?
May 26, 2016 at 2:56 pm #143445
It is iPad/iPhone only I am afraid.
Andy
October 26, 2016 at 12:38 pm #144737
Anyone tried it? Reviews? Does it work properly? Does Eventide endorse this app officially?
Tom
Tom
This would be great to know.
If good, it is major step forward.
September 14, 2018 at 11:26 pm #150090
I just found this app and downloaded it. Works well, but the delay in screen refresh is a bit of a downer, since that is the main reason I got it. I also had some weird dropped signal issues, but that could very well be user error. Still, if you have an iPad, it is definitely worth it. I had previously been using a Lemur layout someone developed, but this is far better. Kudos to the app developer!
Can you get in touch with me at support@iosaudio.co.uk and we can look at the problems you are seeing.
Cheers
Andy
February 10, 2021 at 8:47 am #157128
Not available anymore on iTunes or Mac Appstore, has it been discontinued?
L.
April 28, 2021 at 12:02 am #157727
I’m unclear on how it talks to the Orville and Eclipse. What connections are needed?
April 28, 2021 at 6:42 am #157729
It uses midi, so there are a few ways to connect:
1. You can use a midi interface connected to the iPad.
2, The iPad connected to a computer via wifi and the computer connected over midi to the Eventide device:
3. A midi interface connected to the Eclipse that supports network midi, like the iConnect range.
4. A bluetooth midi dongle plugged into the eventide device. I use the Yamaha MD-BT01 with my Eclipse.
Cheers
Andy
October 27, 2023 at 2:39 am #175248
Is there anything to do with the app for an iPad to detect the Eclipse device ? My Eclipse is connected MIDI In and Out to the USB/lightning of my iPad but the app does not see my Eclipse.
The iPad clearly sees the MIDI interface (In and Out) which is connected to my Eclipse.
But the app does not detect my eclipse. Same issue with a DSP7500.
Any help would be appreciated.
Thanks,
André
October 27, 2023 at 11:03 am #175249
thank you man! it works on my M1 mac as well
i use it with eclipse
L.
I just looked on the App Store on an iPad here and it is available.
What IOS version do you have and what country are you in?
Cheers
Andy
