Is it possible to loop external effect pedals into the H90?
Home Forums Products Stompboxes Is it possible to loop external effect pedals into the H90?
Viewing 3 reply threads
    • #178115
      keziahj
        Is it possible to configure the inputs and output of the H90 in such a way that I can generate one or even two effect loops? In other words, is it possible to loop external effect pedals into the H 90?
        Many thanks in advance for your help!
        Michi
      • #178117
        keziahj
          is this the answer?
          https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/setup/two-mono-inserts.html
          Is “INSERT” equivalent to a FX LOOP?
          Many thanks!
          Michi
        • #178118
          winihh
            Yes… you have 2 Loops… and you can place your “insert” whereever you want … even before the effects of the H90.
            In this way the H90 is like a command-center for your effects… I use it in this way. It is great!
          • #178119
            keziahj
              GREAT²³ 🙂👌✅
