I'm really intrigued by the possibility of consolidating on a ModFactor
and a TimeFactor. Between them they cover just about everything I need
at a good price and a nice, tiny form factor. I've got a question about
the ModFactor though: is it true stereo? Can I have one algorithm
applied to *just* the left input -> left output and another
algorithm applied to *just* the right input -> right output?
I ask because when it comes to modulation effects I like to run some
things in front of my amp (auto-wah, phaser for example) and some
things in the loop (chorus, tremolo [although even this I'd like to be
able to move around per-patch]). If the ModFactor is true stereo I
could use one input/output pair for the "in front of the amp" effects
and one input/output pair for the "in the loop effects. And then just
setup my patches accordingly.
I was thinking: Guitar -> ModFactor right input -> ModFactor
right output -> front of amp. And then: FX send -> ModFactor left
input -> ModFactor left output -> FX return.
Can you tell the ModFactor that even though you're using left and right inputs and outputs, not to run the effects in stereo?
