Home › Forums › Products › Stompboxes › Is there a MIDI implementation for changing USER LISTs?
- This topic has 1 reply, 1 voice, and was last updated 2 years, 10 months ago by
joecozzi
Eventide Staff.
November 30, 2022 at 8:04 pm #167341
Is there a MIDI implementation (maybe via MIDI CC#) for changing USER LISTS ?
It seems that the only way to change a LIST, is directly on the H90 using the Performance Knob, in EDIT mode.
Although there are 99 program positions per LIST (Ie; USER List 1 -4)… My application for controlling the H90 during live performance is 100% MIDI control… for Enabling/Disabling of P/A/B controls… as well as being able to MAP & set various algorithm parameters on the fly via CC# via control patches from another device in my live application… there still may be a point where a program or set of programs may reside in a different LIST. It looks like I can’t get to a different USER LIST in via MIDI control. Maybe I’m just missing it in the documentation? But I also don’t see any mapping option in the system parameters page.
I guess if there isn’t one… maybe in a future Firmware update? (BTW… excellent layout for mapping CC# per control in Connect App).
I look forward toward any response on this issue.
Thanx!
November 30, 2022 at 8:13 pm #167342
Hi RikjCarty,
Thank you for the complement and for supporting Eventide!
No, but it’s actually a good suggestion I will pass on.
Hmmm, I think you may be referring to using the Quick Knobs to narrow the List when searching for algorithms and presets. This is not for choosing the main Playlist, which can only be done in Global System Settings.
All of this is currently possible.
You are correct, but it’s a good suggestion.
- The topic ‘Is there a MIDI implementation for changing USER LISTs?’ is closed to new replies.
