November 6, 2009 at 1:13 pm #106613lionelredParticipant
Just trying to configure my H8000FW but it seems different from internet pics
look at the attachments
November 6, 2009 at 1:37 pm #119412IDeangelisMember
The attachment was a rear panel pict of the H8000FW.
How's yours?
I
November 6, 2009 at 1:54 pm #119413lionelredParticipant
try this having trouble uploading
November 6, 2009 at 2:28 pm #119416lionelredParticipant
try this
November 6, 2009 at 2:30 pm #119417IDeangelisMember
It looks like your unit is the original first version, labeled "H8000". Then the H8000A followed (with 4 analog I/Os) and finally the H8000FW with 4 analog I/O, FireWire and 8 AES-EBU channels on a DB-25 connector.
So, your unit can be only used as a stereo machine thru analog I/Os. Any other reset must be used thru AES or ADAT…
….or you can upgrade it to H8000FW! The Eventide website has information on the costs and details.
all the best
I
November 6, 2009 at 4:09 pm #130541lionelredParticipant
IT DOES HAVE THE FIREWIRE INSTALLED!?!
November 6, 2009 at 4:11 pm #130542IDeangelisMember
No FireWire.
Your unit is an H8000, NOT an H8000FW.
I
November 6, 2009 at 4:14 pm #130543IDeangelisMember
Your pictures don't show the left side of the rear panel. But I see that the analog I/Os are only 2 and that was typical of the original H8000.
I
November 6, 2009 at 4:30 pm #130545lionelredParticipant
here is the full image
November 6, 2009 at 4:39 pm #130546IDeangelisMember
Ok
that is an H8000 with FW and AES/EBU on DB25 but the analog I/Os are not what they should be.
It looks like an H8000 that has been upgraded in an incomplete way. You should contact support@eventide.com, providing the unit serial number and describing where did you buy it.
best
I
