Is this routing possible on H90?
Home Forums Products Stompboxes Is this routing possible on H90?
Viewing 4 reply threads
    • #176918
      Bassmagnetic
        Is it possible to use the H90 in Dual mode but with with the 2x fx outputs mixed to ouputs 1+2? atm it only seems possible to discreet outputs per fx on outputs  1+2 and 3+4, unless I’m missing a setting somewhere?
      • #176919
        joecozzi
          Hello Bassmagnetic,
          While there isn’t away to combine the signal of both paths in Dual Routing mode, this is possible in Insert Routing mode using the inserts. Check out this video on creative connections to learn how: https://youtu.be/0G_WtfUatSc?t=1190&si=TIHeGmrSR8scvFxQ
        • #176920
          Bassmagnetic
            Perfect, thanks for the swift reply, this is exactly the setup I was looking for, clearly explained in the video too 🙂
          • #176922
            Bassmagnetic
              one related question, is it possible using the insert method in parallel (for 2x fx for 2x different instruments), to have a stereo input 1+2 and a mono input 3?
            • #176928
              Bassmagnetic
                In Dual mode the inputs normalise so both mono and stereo signals can be used for the 2 different FX, in insert mode it seems its only expecting 2x stereo, is this correct? Can’t seem to get it functioning as it shows in the video.
                It’d be great to have Dual mode outputs mix to 1&2 and be able to control input levels like a mixer.
