Jump over algortihms connections
Home Forums Products Rackmount Jump over algortihms connections
    • #172537
      kims
        A tip to improve 🙂
        Its a pity that you cant(?) “jump over” algortihms connections in the fx-chain: example i have the h3000 micropitch on the first top row connected to adat 3-4
        then out to 3-4 adat
        In the next algorithe below h3000 micropitch i wanted to connect algorithme monodelay from adat 1-2 and out to adat 1-2
        That would be awesome if i could jump over the existing algorithmes in and output in fx-chain 1 etc
        Or can it do that? i tried with no success
        I know its possible to do that by using next fx-chain, but that is wast
      • #172538
        Puppeteer
          Just put it somewhere else in the grid that isn’t directly below.  Then you can connect it how you want.  You can have 4 algorithms in parallel in a chain if you want.
        • #172539
            Yes, it seems like what Puppeteer described should work for your scenario.
            You can check out the factory session 901 Reverb Buses for an example of a similar routing.
