Kill Dry Question
Home Forums Products Stompboxes Kill Dry Question
    • #172481
      ptw2uk
      I am running the H90 through my Boss ES8 loop switcher in loop 7 with stereo. I am using 3 amps in a Wet Dry Wet configuration. The H90 is routed to only the wet amps. How do I utilize or engage Kill Dry on the H90? I keep hearing about it but I do not see any step by step directions on how to activate kill dry on H90 so the signal coming from it to my amps is purely wet. Thanks!
    • #172482
      joecozzi
      Kill Dry can be applied on a global level. For this, go into the System Menu > Global > second page – set Kill Dry to ON.
      or, Kill Dry can be applied on a Program level. Each individual Preset can have Kill Dry enabled. Press the Parameters button, and on the last page of parameters for each preset you’ll find a kill dry option. You have the choice of it following the global setting we just talked about or you can force it to On or Off depending on the program.
