Home › Forums › Products › Stompboxes › Knife Drop won’t connect to h9 connect
I’ve tried everything it says to do. Power cycle and restart and everything. It gives me an error every time.
Best thing for you to do is contact support@eventideaudio.com and mention your operating system and version.
Just making sure, you downloaded H90 Control, correct? H9 Control will not work. Make sure you are on the latest version 1.8.16.
Can I connect Knife drop to H90 control app on Ipad?
Like my H9 with H9 control app…
If so, how?
Thanks
Looks like it only supports usb connectivity. No Bluetooth. That’s cool.
It’s possible to connect Knife Drop to an iPad running H90 Control using a USB camera adapter and the corresponding USB mini to USB-A cable. However, updates can only be performed via USB on MacOS or Windows.
