Latency/lag with presets
Home Forums Products Stompboxes Latency/lag with presets
    • #116516
      When I’ve selected a preset and play there is a significant latency or lag between what I play and the sound coming thru the amp. Dialing input gain to 18 helps but it is still noticeable. This doesn’t occur with all presets but many of them. Any help?
      Thanks.
    • #157947
      joecozzi
        Have you checked to make sure that the presets that are giving you this problem aren’t programmed to be in an alternate routing other than “Normal?”
        My advice would be to back up your presets and System Settings and conduct a factory reset. If that doesn’t work, reinstall the firmware and reset it again.
      • #157949
          You may just be hearing the effect sound. Make sure KILLDRY is set to OFF, and any MIX knobs are set midway.
          If you are running mono, make sure you are using INPUT 1 or OUTPUT 1 as appropriate.
        • #157961
          This worked!! Thank you
