- This topic has 93 replies, 32 voices, and was last updated 7 hours, 53 minutes ago by
studiothrills.
October 26, 2021 at 9:14 am #159764
All Eventide and Newfangled Audio plug-ins are compatible with:
- macOS 15 Sequoia
- AAX, AU, VST2, and VST3 natively support Apple Silicon and Intel processors
- Important info for users running Intel machines or GarageBand under Rosetta: Newfangled Audio plug-ins cannot currently be opened in GarageBand 10.4.4 on macOS Big Sur, however they will open in GarageBand 10.4.5 on macOS Big Sur. Newfangled Audio plug-ins cannot currently be opened in GarageBand 10.4.4 and above on macOS Monterey and above. Please hold off updating GarageBand until this issue is resolved.
- Windows 11
All Eventide and Newfangled Audio plug-ins are 64-bit only. See each plug-in’s product page for further OS requirements.
- macOS 15 Sequoia
October 27, 2021 at 3:19 pm #159806
Thank you for this notice of Monterey OS compatibility. Is there a special update procedure for my Eventide plug-ins? Or do I just download and re-install the entire plug-in? And if so, what is that procedure in order to avoid errors. As of now, Logic will no longer recognize my Eventide plugins since I updated to the Monterey OS. Thank you.
-Sean Mahon
October 28, 2021 at 10:54 am #159832
There is no special update procedure, just download and run the installers which can be found here: https://www.eventideaudio.com/downloads/?mc_cid=7f97e0e1cb&mc_eid=3d50134998
-Tyler
December 8, 2021 at 9:34 am #161208
I’ve download it and run the installer but have this message on my MacBook Pro M1 below.
The plug-in never appears on the plug-ins section in my Logic Pro X Daw
Thanks
December 8, 2021 at 9:46 am #161209
Please make sure that you have both Read and Write privileges on the /Documents/Eventide folder, as well as the /Users/Music folder, and then run the installer. This article can help you with that: https://support.apple.com/guide/mac-help/change-permissions-for-files-folders-or-disks-mchlp1203/mac
If you are still getting the error, try manually copying the contents of Documents/Eventide to Music/Eventide, and then running the installer.
If neither of those work, please see a few posts down where another user found their own solution you can try.
October 27, 2021 at 4:45 pm #159812
Does this include Newfangled Audio plugins? (The Downloads page is currently giving me a 504 Gateway Time-out error, so I can’t check what’s been updated.)
October 28, 2021 at 1:01 pm #159842
In case anyone had the same question: The plugins from Newfangled have not been updated for macOS Monterey or M1 yet. They are currently inviting beta testers to an M1 native build on their Facebook page.
October 27, 2021 at 6:47 pm #159819
The “Get Latest Installers” link you sent in the email is not working, and when I try to access my product page after logging in, it requires me to type my iLok name, but after I do that nothing happens. You could make things a little easier for people.
October 28, 2021 at 10:56 am #159833
Sorry for the inconvenience. The downloads link should now work for you: https://www.eventideaudio.com/downloads/?mc_cid=7f97e0e1cb&mc_eid=3d50134998
Please try again and let me know if you have any issues.
-Tyler
October 28, 2021 at 3:33 am #159829
when I try to install the latest plugins onto an M1 iMac with Monterey I am getting an error when the installer is trying to copy the files into the default location
“Error copying file from /Users/(username)/
Documents/Eventide/Blackhole to /Users/
(Username)/Music/Eventide”(username) replaced.
only thing I did did apart from defaults, was to deselect all plugin types apart from Audio Units and the documentation.
I have tried several times, rebooted, same results.
I also get the same with H9 Bundle
as well as Anthology.
when I look in the destination directory, it does create the folder for the plugin, but it is empty
October 28, 2021 at 5:09 am #159830
when I try to install the latest plugins onto an M1 iMac with Monterey I am getting an error when the installer is trying to copy the files into the default location “Error copying file from /Users/(username)/ Documents/Eventide/Blackhole to /Users/ (Username)/Music/Eventide” (username) replaced. only thing I did did apart from defaults, was to deselect all plugin types apart from Audio Units and the documentation. I have tried several times, rebooted, same results. I also get the same with H9 Bundle as well as Anthology. when I look in the destination directory, it does create the folder for the plugin, but it is empty
Hi there
Im getting this copying error too for the new installer but using Catalina, it also seems to have stopped my previous installation from showing up in my plugins now so I dont have use of Eventide at all
Hope you can help
October 28, 2021 at 10:59 am #159834
For those of you who are getting the copying error when running an installer:
Let me know if that solves the issue.
-Tyler
October 28, 2021 at 11:35 am #159836
OK, renamed the /Documents/Eventide folder to /Documents/OLD_Eventide and the installer worked fine then
October 28, 2021 at 12:12 pm #159839
This worked! Thanks very much!
October 29, 2021 at 12:36 pm #159886
Hi, I am remaining on Catalina (desktop) and Mojave (laptop). Is there any benefit or necessity to update at this time? Thanks!
October 29, 2021 at 3:43 pm #159888
There’s no harm in leaving your plugins as they are if you don’t want to update them at this time.
November 3, 2021 at 4:50 pm #159953
HI,
A YEAR AGO I BOUGHT MYSELF THE EVENTIDE PLUG-INS FACTORY AND BAND-DELAY. ALL WAS WELL AND WORKED PERFECTLY.
AFTER A BREAK OF MAKING MUSIC, NOW I SEE THAT THEY ARE NOT COMPATIBLE ANYMORE WITH Logic Pro X ON MY IMAC.
I STILL HAVE Mac OS SIERRA VERSION 10.12.6. I TOOK A SNAPSHOT OF HOW THE ERROR MESSAGE LOOKS LIKE.
COULD SOMEBODY HELP ME PLEASE ? THANKS IN ADVANCE
DYLAN
November 3, 2021 at 6:01 pm #159954
Hi, sorry to hear about your issue.
First, can you try installing the latest iLok License Manager, as well as the latest builds of your Eventide plug-ins? The installers can be found here: https://www.eventideaudio.com/downloads/?mc_cid=7f97e0e1cb&mc_eid=3d50134998
Please restart your machine after installing and see if you are still getting the validation error in Logic. If that doesn’t fix the issue, try highlighting each plugin and selecting “Reset and Rescan Selection“.
Let me know what happens.
-Tyler
November 10, 2021 at 11:20 am #160479
Unfortunately, that didn’t work. But now I received a new message when I tried to open iLok License Manager. Like I said before I still have an older Mac OS version (10.12). So I downloaded the 10.4 or below version (Tiger) of the license manager. Could it be that the Tiger version isn’t sustainable anymore?
Many thanks for helping me out!
November 10, 2021 at 11:40 am #160480
It looks like the most recent build of iLok License Manager supports back to Mountain Lion, so you should be okay with that, and I’d suggest re-installing that and rebooting. (I would probably not count on a Tiger install working)
Which version of the plugins do you now have installed? In the screenshot above I see v. 3.7.4 and there are more recent versions for both, though maybe you’re already updated to the latest.
Once you have the latest for iLok and the plugin (and have rebooted), could you let us know if you’re still getting the same validation error? (A screenshot on that is helpful here)
Another helpful thing to test is whether the Eventide plugins load in another DAW. (Reaper is handy for this since it has a free trial mode)
December 3, 2021 at 10:46 am #161130
Hi again,
Sorry for the silence.
As you suggested, the plugins work perfectly on Ableton. Both are at v.3.7.9 and I have installed the latest version of iLOK license manger, the Mountain Lion. Don’t understand why Ive installed the Tiger version in the first place. My mistake..
But still the same problem with Logic Pro X. So clearly the problem lies with my Logic Pro DAW ?
December 3, 2021 at 3:58 pm #161137
Thanks for providing that screenshot. Looking back at what you’ve posted, it’s not clear if you were ever able to get to the “Reset and Rescan Selection“ step. Can you please try highlighting each plugin and selecting “Reset and Rescan Selection“ and posting a screenshot of the window?
December 4, 2021 at 10:24 am #161149
I did as you ask but the Audio Unit Validation Result was way to long to get a screenshot out of it properly. It said that all Logic, Apple, NI and Spectrasonics were successful validated. Except Eventide and D16. So here’s a screenshot of the ones that aren’t successfully validated.
Now I realize that I also can’t find my Ozone 8 plugin from Izotope in my Audio Unit Section, only NI and Apple. As you can see on the screenshot it said that my Ozone 8 is not authorized. Don’t understand anything of it.. I never had any issues like this before.
Thanks again for reaching out!
December 6, 2021 at 1:10 pm #161165
Thanks for providing this screenshot. Can you please try the reset and rescan again, but this time only highlight H3000 Factory and H3000 Band Delays? After that, you can copy the text output of the window and paste it here rather than uploading another screenshot.
December 7, 2021 at 1:20 pm #161201
validating Audio Unit H3000 Factory by Eventide:
AU Validation Tool
Version: 1.6.1a1
Copyright 2003-2013, Apple Inc. All Rights Reserved.
Specify -h (-help) for command options————————————————–
VALIDATING AUDIO UNIT: ‘aumf’ – ‘Fact’ – ‘TIDE’
Manufacturer String: Eventide
AudioUnit Name: H3000 Factory
Component Version: 3.7.9 (0x30709)* * PASS
TESTING OPEN TIMES:
COLD:
FATAL ERROR: OpenAComponent: result: -1,0xFFFFFFFFvalidation result: couldn’t be opened
validating Audio Unit H3000 Band Delays by Eventide:AU Validation Tool
Version: 1.6.1a1
VALIDATING AUDIO UNIT: ‘aumf’ – ‘BDls’ – ‘Tide’
AudioUnit Name: H3000 Band Delays
TESTING OPEN TIMES:
COLD:
November 12, 2021 at 7:39 pm #160534
I have bought splitter. I have a m1 MacBook and I upgraded MacBook to macOS Monterey. I am using Logic Pro. when I am installing spliteq Logic Pro is not opening. I tried to open logic with rosetta and natively. But it looks spliteq doesn’t not compatible with logic
November 15, 2021 at 10:49 am #160569
Can you be more specific with what the issue you are having is? Are you getting an error message when you try to open Logic?
We were able to open SplitEQ in Logic running both natively and with Rosetta on an M1 machine without any issues.
November 15, 2021 at 10:56 am #160570
Could you send us your Support Info? That’s useful for tracking issues like this down. (Right-click on the Eventide logo in the plugin, then choose “Copy Support Information to Clipboard” and paste it in)
November 23, 2021 at 10:05 pm #160841
thus is all that shows up when I open split eq in logic? help!
November 23, 2021 at 10:07 pm #160842
nvm fixed it
November 28, 2021 at 4:43 am #160905
Will there eventually be native m1 AAX support for Monterey ? Apologies if dumb question, Recently made the jump to M1 and still attempting to make sense of it all
November 29, 2021 at 1:18 pm #160951
Hey, we intend to eventually natively support AAX on M1 – but first, Avid needs to update Pro Tools / AAX with native M1 compatibility.
November 28, 2021 at 7:55 pm #160916
Hi 🙂 I installed 3.7.11 however my plugins are running Intel in my Logic sessions on the M1 Max. Any ideas?
November 29, 2021 at 1:26 pm #160952
Hey, could you confirm that Logic is being run natively as M1? If you navigate to Logic in your Applications folder, and right-click and select “Get Info”, is the “Open using Rosetta” box checked?
November 29, 2021 at 3:32 pm #160971
The checkbox is not checked.
December 3, 2021 at 7:20 pm #161139
Thanks for checking. We’ve been able to reproduce here, and this will be fixed in the next update.
December 3, 2021 at 9:59 pm #161146
Dope! Thanks 🙂
February 3, 2022 at 11:35 am #162000
Hey, just wanted to let you know that M1-native builds for Octavox and Quadravox have been released: https://www.eventideaudio.com/downloads/
December 9, 2021 at 1:07 am #161213
I can’t get any of the newfangled mastering plugins to open w/ the latest Ableton beta 11.1b7 running on apple silicon native.
VST3 can’t scan when I try to scan plugins and I also can’t open it with AU either:
Punctuate could not be loaded. Please contact the software publisher for support using this software.
Error details:
execve failed: No such file or directory
December 9, 2021 at 11:37 am #161214
I can’t get any of the newfangled mastering plugins to open w/ the latest Ableton beta 11.1b7 running on apple silicon native. VST3 can’t scan when I try to scan plugins and I also can’t open it with AU either:
Punctuate could not be loaded. Please contact the software publisher for support using this software. Error details: execve failed: No such file or directory
These should work (they do here). I think you emailed as well, right? If so, let’s investigate there. If not, please contact support at newfangled audio dot com.
Thanks,
Dan
December 9, 2021 at 11:41 am #161215
Yep I emailed you through the contact form before finding this forum. Sorry for the double message.
December 9, 2021 at 2:43 pm #161217
Just to make it clear in case it isn’t. Elevate Mastering Bundle was Monterey and ARM Native compatible starting with version 1.9.0. Generate and Pendulate were Monterey and ARM Native compatible starting with 1.2.5. All Newfangled Audio plug-ins are Windows 11 compatible.
January 5, 2022 at 6:25 pm #161475
Hi. I’m still seeing (in early January, 2022) issues with my Eventide & Newfangled plugins running on Mac M1 w/ Monterey: even with current Eventide installers such as H9 Series, etc. – Final Cut Pro is reporting incompatibility on pretty much all of the Eventide AU and Newfangled (Elevate bundle) AU plugins. Am I missing something? Thanks in advance.
January 5, 2022 at 7:43 pm #161476
We don’t test on FCPX, but I actually believe I know what this issue might be. Can you email me at support at newfangled audio dot com and I can make you a test build that might fix this?
January 24, 2023 at 1:52 pm #168624
Hi Dan,
Apologies if this answered elsewhere but I couldn’t find the info….
Is the AAX version of the Elevate bundle apple silicon native? If not, do you have an idea of when it will be?
Thanks.
January 24, 2023 at 2:34 pm #168625
Literally working on it right now. I’m hoping to have it out next week, but I’ll send out an email when it’s ready.
Dan
February 2, 2022 at 6:48 am #161936
Hey, cannot make SplitEQ even start on my latest M1 Max macbook. It worked on my previous Intel one but latest 1.0.4 version on M1 makes Bitwig scan it forever, Ableton just doesn’t see it. Doesn’t look like SplitEQ is M1 compatible, and I specifically installed only VST 2/3 versions.
February 2, 2022 at 9:30 am #161939
Sorry you’re having issues getting SplitEQ to run. All of our plug-ins are M1 compatible and have been tested. Please carefully follow the troubleshooting steps below and let me know what happens:
Mac:
Confirm you have the latest version of your plug-in installed: https://www.eventideaudio.com/products/plugins
Confirm that you have the latest version of iLok License Manager installed (www.ilok.com).
Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
Close your DAW, and delete the following files:AAX: Mac HD/Library/Application Support/Avid/Audio/Plug-ins/Eventide/<plugin name>.aaxplugin
VST: Mac HD/Library/Audio/Plug-ins/VST/Eventide/<plugin name>.vst
AU: Mac HD/Library/Audio/Plug-ins/Components/<plugin name>.component
Presets and Docs: ~/Music/Eventide/<Plugin Name>/ (whole folder)
Open your DAW and rescan your plug-ins, and then shut your DAW again.
Deactivate and reactivate the plug-in license in iLok License Manager.
Reinstall your plug-in
Reopen your DAW and rescan your plug-ins.
AudioUnit only: If still not showing, some macOSes occasionally require a restart for Audio plugins to correctly scan.Live 9 and below:
Go to Preferences->File Folder and Option/Alt-click “Rescan Plug-ins” to force a deep rescan.
Live 10+:
Go to Preferences->Plug-ins and Option/Alt-click “Rescan” to force a deep rescan.
Note that the “deep rescan” is not the same as just clicking rescan in Live.
February 2, 2022 at 9:52 am #161940
tbskoglund thanks, I didn’t have iLok installed on this new machine, that was it.
February 2, 2022 at 10:00 am #161941
You’re welcome, glad to hear it was an easy fix!
February 23, 2022 at 9:25 pm #162444
Hello, just checking in…Is it still the case that those of us with a Macbook with M1 processor running Mac OS Big Sur with Garageband 10.4.5 can NOT upgrade to Mac OS Monterey without breaking the Eventide H9 plugins (that currently work)? I’m really wanting to upgrade to Monterey but have a few projects on the go in Garageband 10.4.5 using your awesome plugins and I’m concerned that I’ll lose those effects. Any new info on the status of this issue would be helpful and greatly appreciated. Thanks in advance!
February 24, 2022 at 11:31 am #162461
Yes, this is still the case, unfortunately. Upgrading your machine to Monterey will break compatibility with our plug-ins in GarageBand 10.4.5. Just to clarify, this is not an M1 specific issue. We have no updates at this time but we are looking into the issue and will update this post as soon as we have news. Sorry for the inconvenience.
March 9, 2022 at 11:48 am #162741
Hi, I’m trying to installing the H9 Plugin bundle on my new Mac Mini (with M1 with Big Sur 11.5.2).
It’s a couple of hours that stays like this.
Tried various restart and reinstall without success.
Any ideas
Ema
March 9, 2022 at 11:56 am #162744
Hello, sorry to hear you’re experiencing issues. Can you be more specific with what is happening? Does the installer freeze at some point? Can you please confirm you are using the latest installer? https://www.eventideaudio.com/downloads/?product=H9+Plug-In+Series
March 9, 2022 at 1:00 pm #162750
Hi tbskoglund and thank you.
I attached a screenshot in my previous post, don’t know why it isn’t available, however: I installed the latest installer. After that, when I open a daw (Logic or Luna) it freezes while scan new plugins. Now, after a couple of our and several restart it seems works fine.
Thank you again
March 9, 2022 at 1:07 pm #162751
You’re welcome, let me know if you run into any other issues.
March 15, 2022 at 7:55 pm #162828
So now that GarageBand 10.4.6 has been released, is it now safe to upgrade my Macbook Air with M1 processor to macOS Monterey without breaking the H9 Plugin functionality that I currently have with macOS Big Sur and GarageBand 10.4.5?
March 16, 2022 at 2:15 pm #162862
I’m sorry, I just updated to GarageBand 10.4.6 to test this with Monterey and nothing has been changed regarding the plug-in compatibility. Please hold off on updating for now. I’ll be sure to let you know when we have any updates.
March 22, 2022 at 2:48 pm #162947
If you are running GarageBand natively (not through Rosetta) on your M1 machine, then GarageBand will allow you to open Eventide plug-ins and you should be ok to update to Monterey.
March 22, 2022 at 9:05 pm #162952
Hi tbskoglund. Thanks for the message today. I successfully updated to GarageBand 10.4.6 and confirmed that it was running natively (not through Rosetta). I then upgraded my MacBook Air M1 from Big Sur to Monterey and can confirm that the Eventide H9 Plugins are still visible in GarageBand. The only thing I noticed is that upon launching GarageBand, I was prompted to lower my security settings to allow the plugins to work. Once I allowed that, GarageBand opened up and everything was perfect. Thanks again for your help and prompt responses!
March 23, 2022 at 1:50 pm #162969
Great, thanks for the info and glad to hear you got this working!
October 26, 2022 at 10:46 pm #166102
Hello again. Now that Mac OS Ventura has been released, it would be great to know if the Eventide H9 Plugins are compatible before I update (MacBook Air M1 machine running GarageBand 10.4.6). Please advise once you’ve had a chance to test. Thanks!
October 27, 2022 at 2:08 pm #166106
Hi, we have completed testing and are working through several bugs that were discovered. We will make an announcement once we are fully compatible.
November 29, 2022 at 1:06 pm #167238
Eventide plugins are now compatible with macOS Ventura – please download the latest installers from the Downloads page.
Please note Newfangled Audio plugins are not yet compatible with macOS Ventura. Newfangled Audio is currently working on compatibility – check back soon.
January 5, 2023 at 10:34 am #168261
Greetings, is there a page or info that detail which plugins can run natively on an Apple silicon based Mac?
January 5, 2023 at 10:44 am #168262
Yes, this forum post is used to detail OS compatibility and we update the main post at the top with the latest specs. All Eventide and Newfangled Audio plug-ins natively support M1.
January 5, 2023 at 11:19 am #168263
Thanks tbskoglund, I’m having trouble getting my Eventide and New Fangled Audio plugins to load in Pro Tools 2022.12 while running native, without using Rosetta.
January 5, 2023 at 11:34 am #168264
Isn’t Protools only just in Beta on Apple silicon at the moment?
January 5, 2023 at 12:10 pm #168265
@badmelonfarmer Yes! It’s running natively on the M1 and M2 processors. It’s a huge gain in performance. I’m trying to determine if Eventide plugins are compatible. This thread reads that they are but they are not loading in Pro Tools. Do they require Rosetta 2 or can they operate natively on Apple Silicon?
thanks
January 5, 2023 at 12:37 pm #168270
Working for me fine in Logic, maybe an issue in the Pro Tools side? Given it is in beta?
January 5, 2023 at 12:40 pm #168271
@badmelonfarmer a mix up on my end, “Eventide” plugins are working the “Newfangled” plugins are not (AAX Native). I finally used my eyes to read that they are NOT supported. I just assumed they were the same as Eventide…..I’m dumb.
Patiently waiting…ha
January 5, 2023 at 8:47 pm #168289
Yes, Newfangled Audio stuff does not yet support AAX Native. We plan to support it ASAP, but we’re still wrapping up some Invigorate related stuff first.
Dan
January 30, 2023 at 6:48 am #168719
Hi, most of my Eventide VST2 and VST3 plugins don’t work on Ventura on my new Mac Studio running Ableton. Audio Units are fine, but to open older projects I have to run Ableton in Rosetta. Any chance of a working update soon?
January 30, 2023 at 9:58 am #168733
Can you please confirm that you are using the latest versions of the plug-ins? The latest installers can be found here: https://www.eventideaudio.com/downloads/
Can you also provide some more information about what is happening? When you try to open an older project natively on your new machine, is there an error message?
January 30, 2023 at 11:11 am #168746
Thank you for your quick reply. I managed to get the VST3’s to work by moving them out of the Eventide folder they were installed in, straight into the VST3 folder.
What remains is some VST2 plugins not showing in the Ableton plugin folder.
When I open an older project featuring those plugins, there’s an error message saying the plugins are missing.
I don’t mind moving to VST3, but would like to be able to open older projects.
January 30, 2023 at 12:23 pm #168753
You’re welcome.
I would first suggest a deep rescan of your plug-in folder in Ableton by Option/Alt-click “Rescan Plug-ins” (note this is not the same as just clicking “Rescan Plug-ins”)
If that doesn’t work, please try the general troubleshooting steps below:
- Confirm you have the latest version of your plug-in installed: https://www.eventideaudio.com/products/plugins
- Confirm that you have the latest version of iLok License Manager installed.If you already have iLok License Manager installed, open iLok License Manager and select iLok License Manager → Check For Application Updates in the toolbar.
If you do not have iLok License Manager installed, download the installer at http://www.ilok.com and install. - Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
- If steps 1-3 don’t solve your issue, close your DAW and uninstall the plugins.
- Newer plug-ins have an uninstaller is located at /Applications/Eventide/Uninstallers.
For older plug-ins without an uninstaller, delete the following files:- AAX: Mac HD/Library/Application Support/Avid/Audio/Plug-ins/Eventide/<plugin name>.aaxplugin
- VST: Mac HD/Library/Audio/Plug-ins/VST/Eventide/<plugin name>.vst
- AU: Mac HD/Library/Audio/Plug-ins/Components/<plugin name>.component
- Presets and Docs: ~/Music/Eventide/<Plugin Name>/ (whole folder)
- Open your DAW and rescan your plug-ins, and then shut your DAW again.
- Deactivate and reactivate the plug-in license in iLok License Manager.
- Reinstall your plug-in.
- Reopen your DAW and rescan your plug-ins.
March 26, 2023 at 12:26 pm #169922
Am I correct in assuming that Anthology XI is not M1 native compatible and I will need to upgrade to Anthology XII to get compatibility?
March 27, 2023 at 11:28 am #169928
The Anthology XI installer is not M1 native compatible, but you have a few options besides upgrading to AXII. You can run the individual installers of all the plug-ins you own, or you can run the AXII installer and uncheck any plug-ins that you don’t own in the installer helper window. Either of these options will get you up to date with the latest M1 compatible plug-ins, the 2nd option would be the simpler/faster option.
March 27, 2023 at 11:43 am #169929
Great, that worked. Thank you so much!
August 12, 2023 at 6:06 am #173100
still no AAX native yet WHAT?
August 14, 2023 at 1:55 pm #173133
Ah, sorry, Newfangled Audio plug-ins are AAX Native on Apple Silicon (I’m guessing this is what you are referring to?) I’ll have Tom update this post to reflect that fact.
Dan
August 24, 2023 at 11:42 am #173620
I apologise if this is already obvious, but will Anthology XII run natively on an M2 Mac?
August 24, 2023 at 12:31 pm #173621
No apology necessary. Yes it will!
November 2, 2023 at 1:10 pm #175365
Eventide plugins are now compatible with macOS Ventura.
I’m on Ventura 13.0.1. Quadravox works fine in Ableton but won’t open in GarageBand 10.4.8. Any workaround?
November 2, 2023 at 3:56 pm #175374
Sorry to hear the issue. Did GarageBand raise any warnings or error messages when you launched it, or when you tried to open Quadravox?
If you email support@eventide.com answering the above, we can better assist you.
November 10, 2023 at 7:57 pm #175620
If the entire suite is now compatible with Apple Silicon, why do the plugins only show up in Pro Tools when opened with Rosetta?
Did a fresh install, restarted the machine, no change.
Running PT 2023.6 on a Mac Studio w/ Ventura, M1 Ultra
November 20, 2023 at 12:32 pm #175945
Please email support@eventide.com and we can assist further. All of our plugins are compatible with Pro Tools on Apple Silicon.
You could try uninstalling the plugins (/Applications/Eventide/Uninstallers) and reinstalling with the latest from our website. Note that AXII was updated with Apple Silicon support, AXI and AX were not (as they are discontinued).
November 20, 2023 at 6:12 am #175919
I’m experiencing the error message “The plug-in named “Blackhole” isn’t available on your system.” This is after the new Logic Pro 10.8 update. The plug-in itself is validated but not available within the project.
Logic Pro 10.8 on MAC Studio 2022 M1 Max Ventura 13.6.1
November 20, 2023 at 8:25 am #175922
Please see this post for more information: https://www.eventideaudio.com/forums/topic/blackhole-renamed-in-logic-10-8/
March 31, 2024 at 2:36 am #180360
Hi. My eventide plugins are not showing up on my new Mac computer (M2, running Sonoma 14.4). I have authorized them via iLok for this second computer. Are you supporting this environment yet? If not, when do you think you might achieve that support? Sonoma and the Mac Silicon computers have been out for quite a while now. If you do already support this environment, what do you suggest I do to get these plugins working?
March 31, 2024 at 2:49 am #180361
Hi. My eventide plugins are not showing up in Pro Tools on my new Mac computer (M2, running Sonoma 14.4). I have authorized them via iLok for this second computer. Are you supporting this environment yet? If not, when do you think you might achieve that support? Sonoma and the Mac Silicon computers have been out for quite a while now. I AM seeing them in my other DAW (Ableton Live 11) but each plugin I use says it’s not yet activated, so I activated several of them as I needed them. They still don’t show up in Pro Tools, though, and that is my primary DAW now. If you do already support this environment, what do you suggest I do to get these plugins working?
April 1, 2024 at 2:51 pm #180405
Hi, yes our plugins are supported in Pro Tools as well as on M2/Sonoma. Please try the steps listed listed above, and if they do not resolve your issue, email support@eventide.com with your iLok account and a short description of the issue and affected plugin(s).
April 21, 2025 at 11:36 am #189658
Hi there, are there plans to fix the 2016 Stereo Room so it works native on Silicon ARM Macs? I installed version 3.7.11 today on my Mac Studio M3 Max, and Pro Tools does not want to run it natively…. Thanks!
April 21, 2025 at 12:02 pm #189659
Oh, I have to add that I just noticed the AU-version of 2016 Stereo Room version 3.7.11 is running okay native in Logic Pro X. So te problem is AAX I guess? Best regards, Rens van der Meer
