Home › Forums › Products › Stompboxes › latest update now getting error
- This topic has 32 replies, 6 voices, and was last updated 1 year, 3 months ago by
wick.
November 22, 2023 at 5:32 pm #176056
Dethjazz
ParticipantDid the 1.6 update as prompted when connecting and now my Mac will not connect to the h90. says Device Connections Error.
November 22, 2023 at 5:34 pm #176057
Hello Dethjazz,
Have you updated the H90 Control application to version 1.7.1? This should be done first before updating the pedal to firmware 1.6.1.
November 22, 2023 at 5:35 pm #176058
Dethjazz
Participantno me being a dummy did not. I just did download it
November 22, 2023 at 5:41 pm #176059
Dethjazz
Participantafter “quitting” h90 control upon reopening interface was slightly different and prompted to DL 1.6 and now it works. That’s what I get for not reading through everything. I hope this thread helps other dummies like me that don’t take the time to read instructions.
November 22, 2023 at 5:43 pm #176060
Glad you got it working. Thank you for asking for help on the forums. Enjoy the new algorithm!
November 23, 2023 at 3:25 pm #176066
Turbostang2005
ParticipantMy H90 bricked during the update. All lights are on screen is garbled on the bottom
November 23, 2023 at 3:28 pm #176067
Hi Turbostang2005, sorry about this issue. If you power cycle the pedal, does it boot up normally?
November 23, 2023 at 3:29 pm #176068
Turbostang2005
ParticipantI do a factory reset. Does the same thing
November 23, 2023 at 3:30 pm #176069
Turbostang2005
ParticipantWhat do you mean.. Power cycle
November 23, 2023 at 3:32 pm #176070
Can we try booting up in recovery mode?
Connect the pedal via USB
Power down the pedal.
While holding down SELECT, PERFORM, and Quick Knob 1, connect the power. It should boot up in recovery mode. Do you see that on the screen? -
November 23, 2023 at 3:32 pm #176071
Turbostang2005
ParticipantDid power cycle… Same nothing
November 23, 2023 at 3:35 pm #176072
Turbostang2005
ParticipantI see h90 recovery v 1.0.1
November 23, 2023 at 3:37 pm #176073
Turbostang2005
Participant -
November 23, 2023 at 3:39 pm #176074
Turbostang2005
ParticipantAttachments:
November 23, 2023 at 3:39 pm #176076
Turbostang2005
ParticipantNow what should I do?
November 23, 2023 at 3:40 pm #176077
Make sure you have downloaded the latest H90 Control software v1.7.1
– To do so log into your Eventide account.
– Find your H90 in the list of registered products and click “Docs & Downloads.”
– Download the H90 Control version 1.7.1 that corresponds to your operating system, Windows or MacOS.
– Once installed, open the application. Let me know what you see.
November 23, 2023 at 3:42 pm #176078
Turbostang2005
ParticipantDo i still stay in recovery mode? While I update?
November 23, 2023 at 3:44 pm #176079
Yes, don’t do anything with the pedal. On the software go to where the three horizontal bars are at the top left and click “H90 Recovery.” Choose 1.6.11 and click install.
November 23, 2023 at 3:49 pm #176080
Turbostang2005
ParticipantSays not available
November 23, 2023 at 3:50 pm #176081
I’m not sure what you’re seeing. Can you take another screenshot?
November 23, 2023 at 3:51 pm #176082
Turbostang2005
ParticipantOK I got it… Back to working
November 23, 2023 at 3:52 pm #176083
Everything installed correctly for you?
November 23, 2023 at 3:52 pm #176084
Turbostang2005
Participant1.6.11 is current?
November 23, 2023 at 3:52 pm #176085
Yes sir!
November 23, 2023 at 3:52 pm #176086
Turbostang2005
ParticipantNow where are the new presets located?
November 23, 2023 at 3:56 pm #176087
Press the PRESETS button. With the third Quick Knob set the algorithms list to “PolySynth.” Turn SELECT to play that algorithms presets.
If you want to explore Programs with PolySynth presets in them, press PROGRAMS, use the third Quick Knob set the algorithms list to “PolySynth.” Turn SELECT to play that Programs that feature combinations that use PolySynth presets.
November 23, 2023 at 4:07 pm #176088
If we were able to resolve your issue, please update the YouTube comments to reflect H90 Recovery mode helped fix the problem.
November 23, 2023 at 5:13 pm #176089
Turbostang2005
ParticipantI did and thank you for providing excellence in service. Especially on a Holliday.. Polysynth stuff is rad. I play bass usable stuff.
November 23, 2023 at 6:54 pm #176090
kbarber
ParticipantI installed H90 Control app 1.71 (MacOS 11.7.2) and used that to install H90 firmware 1.6.11. It seemed to go fine. I did have to power cycle the H90. When I did, it updated the panel and then updated Bluetooth (separate sequences and both happened automatically when I connected power after doing the firmware update)
I see the new PolySynth algorithm and related programs and presets.
But the app keeps losing the USB connection. When this happens, sometimes it will flip between the H90 showing as “Not Available” and “Connect” on a pretty regular cadence (like, 2 seconds “Not Available” then 2 seconds “Connect”)
And sometimes it just shows “Not Available” until I disconnect and reconnect the USB cable at the H90 (if I disconnect the USB at the computer, nothing changes)
And sometimes, it just shows “Connect” and I can connect. But then the connection gets lost again after maybe a couple minutes. Lather rinse repeat
I do connect thru a USB hub and have not (yet) tried connecting H90 directly to the computer because it’ll take some logistics and because I’ve not had any issue with this connection in the past and other devices connected to the same hub don’t have an issue.
Any advice is appreciated and let me know if I can provide more info.
November 24, 2023 at 7:57 am #176096
kbarber
ParticipantUpdate: I connected the H90 directly to my computer and the connection was totally stable. It’s curious because the other units connected via the USB hub don’t drop, including the Rose (using EDM) and this never happened before I updated the H90 and H99 Control.
On the positive side, this may be moot when H90 can be controlled via Bluetooth, which should be any day now 🙂
November 28, 2023 at 3:22 pm #176247
wick
ParticipantI install the new h90control to my Mac now my. h90 won’t connect to the h90 control
You must be logged in to view attached files.-
November 29, 2023 at 11:04 am #176297
Please try deleting the H90 from H90 Control by clicking the “X” button. You can then add it again by clicking the “add device” button in the top right corner.
You may also find that restarting your computer resolves the issue after deleting/re-adding the device.
Let me know if that works.
November 30, 2023 at 12:05 am #176326
wick
ParticipantDid everything you mention, now I download the 1.6.11.6 firmware then upgrade the h90 it went smooth thanks
