LCD readout truncated on ” insert program” field
Home Forums Products Rackmount LCD readout truncated on ” insert program” field
    • #109598
      On v 4.1, the field to select  a new block to insert in FX A or FX B is truncated and virtually unreadable.  So, when you go to the parameter page to insert a new block and select Program, you can see only 3 letters of the program name and 3 letters of the block name.  This makes it very hard to find the program or block you are looking for.
      Is this a problem others are having?  The manual shows that the display should show the whole program or block name, whichever is selected.  I am seeing only the first couple letters of each.
      can anybody confirm or replicate this behavior?
      thx
    • #124297
      Solved this myself.  Just required a reboot.
