October 22, 2009 at 11:32 am #106559
Deefern
MemberHi,
My first Post after all these years since owning two grate Eventide Units in1986-7
Can someone please let me know where I can get the LCD screen for my DSP 4000? Mine has gone Half Dark on Right side and it is getting imposable to read and edit this unit.
Cheers,
Derek.
October 22, 2009 at 12:29 pm #119308
IDeangelis
Member -
October 22, 2009 at 2:44 pm #119311
Deefern
MemberHi IDeangelis
Thanks for your prompt reply, I will get on it.
Cheers
Dee
October 22, 2009 at 2:48 pm #119312
Hi Derek, please include the serial numbers of your units when emailing support@eventide.com. Thank you!
March 19, 2012 at 11:49 am #123243
DSP4000
MemberJust to let people know that if they have this problem with the light going out on the LCD, the backlight is replaceable.
It is just a small flourescent tube (CCFL-Cold Cathode Fluorescent) that can be slid out from behind the display by removing the two small black fixing pins and the cable clamp that holds the high voltage wires that come from the backlight assembly to the PCB.
The backlight assembly can then be opened up to get to the CCFL tube. I haven't done this part and I don't think I'm going to try it. Send it to these guys: http://www.ccflwarehouse.com
I think they can do the job of putting a new CCFL tube into the assembly then you just have to slot it back in behind the display. They can also supply a CCFL tube with the wiring already soldered onto it and you can try putting it back in the assembly if you want. They just need to know the length and diameter of the CCFL tube.
Cheers
January 23, 2015 at 12:47 am #127392
Soulheal
MemberHi,
I have a GTR 4000 Harmonizer and I am currently attempting to work out an approach to fixing a shaded area on the right side of my display screen. I emailed Eventide several times and they told me that the display board was likely going bad and that they do not service this part any more and they can't do much at all for me.
I hadn't heard about the backlight bulb before, do you know if your 4000 has the same setup as the GTR 4000.
Any help to move forward with this issue would be greatly appreciated.
Thanks,
Will
May 20, 2016 at 9:29 pm #143407
zed_90125
MemberGo into SETUP and make sure the contrast and Brightness are set right
May 21, 2016 at 8:37 pm #143413
These screens have not been made for many years (we can't get them). There are always a fair number on eBay at around $250, but you'll want to check the part numbers carefully.
