February 20, 2008 at 11:38 am #105366
Hello Newbie here..
When I set my eclipse in autodim mode (display menu)
It swirls or waves in LCD after about 30 minutes.
When I press any button, it returns to normal display mode.
Is this broken? or usual behavior?
please solve my problem..thanks -
February 20, 2008 at 11:45 am #116986
Hi
it's normal to see a "liquid" fx when the autodim is on. It's the way lcd works.
Autodim saves energy and lcd life. You can use or disable it under SETUP > DISPLAY.
best
I
February 20, 2008 at 12:47 pm #116987
Thanks IDeangelis
BTW, what do you mean by 'liquid'? no offence.. I meant that green lcd literally
just 'swirls' or 'waves' when eclipse is in 'null' or 'no button-action' mode.(in autodim setup).
you meant just 'darker' or 'dim' state of LCD ?sorry for poor english
February 20, 2008 at 1:33 pm #128000
When dimmed, the lcd may look like the low light is trembling, as in a wavy or liquid effect. The names of parameters are clearly visible though and it doesn't indicate a malfunction. It's just a lowered light intensity that shows the nature of the LCD component. Nothing to worry about.
I
February 20, 2008 at 1:44 pm #128001
thanks a ton again ID!
I happened to send my eclipse to service center because I thought it has some
errors on LCD
eclipse totally rocks! i love it to the death!
February 20, 2008 at 4:44 pm #128004
I think it looks quite pretty 😉
February 20, 2008 at 4:55 pm #128005
Yeah! It's trippy stuff…. if you stare at it for a couple of hours–
I
