Home › Forums › Products › Stompboxes › Lead H9(#1)not passing MIDI commands to 2nd H9(#2)
- This topic has 4 replies, 3 voices, and was last updated 3 years, 1 month ago by camn.
December 3, 2021 at 2:36 am #161106KeokiParticipant
I’ve checked to make sure H9#1 (Channel 3) is set on [THRU] to pass MIDI on to H9#2 (Channel 4) but it doesn’t seem as if the command is being passed thru the [MIDI OUT] DIN connector. I’m using an RJM PBC/6X MIDI as the controller. If I connect H9#2 direct to the 6X it does sequence the presets just fine. As soon as I MIDI cable link H9#1 (MIDI OUT) to H9#2 (MIDI IN) the commands intended for H9#2 on Channel 4 don’t seem to pass, or perhaps H9#2 is rejecting them for some reason. I’ve done a bit of research here on the forum and read the manual but this specific issue doesn’t seem to be addressed (other setting MIDI to [Thru] on H9#1. Using H9 Control I don’t see any obvious setting on H9#2 that would cause the commands to be rejected. If it makes any difference the first H9 is a MAX the second an H9. The factory presets on my account show as shared or bundled between all three of my H9s.
December 3, 2021 at 8:45 am #161119
Obviously, it should work. Various things to try:
1) Different cables.
2) Change the order of H9#1 and H9#2.
3) Re-init and re-configure both units.
December 3, 2021 at 11:13 am #161132KeokiParticipant
Nick first up, thanks. I swapped cables last night and reinit & refig’d a couple times. Before I did anything else this morning I swapped boxes with #2 getting the direct MIDI connx with the 6X and #1 getting MIDI IN from #2 using the same cable as I had last night. That works. So one could jump to the conclusion that H9#1’s MIDI OUT plug/circuit is wacko, but I want to wipe #1, reload its Preset List, and reconfig. Once I do that I’ll repost here… Keoki
December 3, 2021 at 12:07 pm #161133KeokiParticipant
Good ole wipe and reprogram. I swear I did this last night but “the box” must have been too tired to pay attention. Regardless the two H9’s are receiving their respective preset calls from the PBC/6X…now I get to add the 3rd H9 and about 4 other MIDI pedals, Fortunately some of these are Strymon and I can use a Strymon Conduit to make those TRS MIDI connections.
December 20, 2021 at 4:17 pm #161316camnParticipant
Too many thrus can be twiddly in the long run.
If I were you I’d think about a thru box of some kind, given your setup is getting pretty great.
